Oil Presusre and Water Temperature Gauge Add-On
   / Oil Presusre and Water Temperature Gauge Add-On
Here is the water temp and oil pressure lines connected to the engine block.
Sent from my iPhone 2.0 using TractorByNet
Sorry about that. Next time I'm on the computer I'll rotate it.
<CGImageProvider 0x15e014a0>
   / Oil Presusre and Water Temperature Gauge Add-On #15
No problem, thanks for posting.
I've decided against mounting the gauges on hood of the tractor... Once they are finally mounted in the "cockpit" I'll post them too, right side up. :D
Jeff
How do you rotate pictures? I have a few that need it. Thanks
The only way I know is to rotate on my pc then re-upload to my message. I have not found a way to do it within TBN.
Finally finished the installation today. I'll get a night photo another time.
50 PSI Oil and 165°F water no load. Matches about the 1/4 mark on the factory gauge.
   / Oil Presusre and Water Temperature Gauge Add-On #20
They look great.
Aren't you worried about hitting them with your knees?
Horse Weathervane (A55853)
Horse Weathervane...
MERITOR SEMI TRUCK REAR END MODEL-C3121L1728 (A57192)
MERITOR SEMI TRUCK...
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
LANES PULL TYPE FERTILIZER SPREADER (A57192)
LANES PULL TYPE...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2019 FREIGHTLINER M2106 26' BOX TRUCK (A57192)
2019 FREIGHTLINER...
