Whats the trick to hooking up hydraulics and not having leaks
   / Whats the trick to hooking up hydraulics and not having leaks #11
This is what I use, follow the directions and give it time to dry. You won't be having leaks anymore!
Good luck
   / Whats the trick to hooking up hydraulics and not having leaks #12
I worked in a cannery with hundreds of hydraulic fittings. When we absolutely, positively HAD to seal a connection, we used LocTite 545.
The price will take your breath away, but it works every time under any conditions I've come across.
   / Whats the trick to hooking up hydraulics and not having leaks #13
I use a loctite type product, I think it's called drip stop.
   / Whats the trick to hooking up hydraulics and not having leaks #16
I use Leak Lock. Great stuff, just remember to store the jar upside down.
   / Whats the trick to hooking up hydraulics and not having leaks #17
I used something similar, called permatex #54540 pneumatic and hydraulic sealant to seal a ORB straight threaded fitting that was machined improperly, not allowing the gasket to seal. Worked great. I now use it for most all my hydraulic connections. Amazon has it for $26. NAPA charged me $37.
   / Whats the trick to hooking up hydraulics and not having leaks #18
I use great white Teflon paste. Non of mine have ever leaked. They are all NPT threads. The stuff is cheap and available at Lowe's. I am sure it is not as good as some of the higher priced more specific Hydraulic sealers mentioned here, but it has worked for me on my hydraulic projects.
Teflon paste sealant took care of 5 out of 6. The 6th one which was the really bad one worked with 3 wraps of Teflon tape. Careful not to have any past the threads and wrapped clockwise facing the threads.
Thank you!
2018 Chevrolet Impala Premier Sedan (A59231)
2018 Chevrolet...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2017 Versatille 260 (A60462)
2017 Versatille...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2020 DRAGON ESP...
