JD 3005 full cage ROPS/FOPS build
   / JD 3005 full cage ROPS/FOPS build #161
Hi,
The hood guard comes off real easy. There are pins on the front held in place by clips, and the back end is held in place by switchable magnets I bought from Grizzly tools. Takes about a minute to remove and replace.
There is a very old thread showing build details. I will see if I can find it, if it still exists. I will post the link if I do.
Bill
   / JD 3005 full cage ROPS/FOPS build #162
Hi,
Bill
Henro: thanks for posting the links to your thread... part of my reason for starting this thread was/is to stimulate the thought and design process for others, and compile our ideas.
I have had no roof or overhead protection on my cage since installed, still undecided on what to use. Expanded metal would allow protection with visibility, but shed no water. An old roof section (ribbed sheet metal) from a van i scrapped was saved and stored, but i cant bring myself to cut a 3'x4' piece out of the middle of a nice 5'x9' sheet of metal! Yesterday I found a piece of 3/4" plywood and put it up there, as I've been in the woods alot lately and wanted something to stop a falling branch other than my head. Temporary but works for now.
   / JD 3005 full cage ROPS/FOPS build #165
When I put a roof on a ROPS cage years ago I went to a sheet metal shop and had them fold up a top and edges with an "X" pressed/formed/folded in the metal like on the side of a furnace. That allowed it to shed water and was my cheapest option that looked good. It looked factory.
   / JD 3005 full cage ROPS/FOPS build #166
I've been thinking about either a used dumpster lid or a used golf cart canopy. :confused3:
   / JD 3005 full cage ROPS/FOPS build #167
Golf car canopies are almost always too small and dumpster canopies look like you put a dumpster canopy on the tractor. I'll try to find a photo of my sheet metal shop canopy and you would be impressed. Everyone thought it was factory and it was just thin sheet metal with one of those folded "X's" into it to hump it up a bit and shed water.
   / JD 3005 full cage ROPS/FOPS build #168
I used a canopy off an old JD backhoe.
   / JD 3005 full cage ROPS/FOPS build #169
Put a golf cart top on mine just something I had laying around I repurposed.
   / JD 3005 full cage ROPS/FOPS build #170
That's a good looking fit. Do you happen to know the measurements of your top? I want to put a top on my MX5100 but the ROPS is really wide and I cannot find one to cover the width of the framework.
2019 CATERPILLAR 316FL EXCAVATOR (A51246)
2019 CATERPILLAR...
2011 VANGUARD 53x102 DRY VAN (A53426)
2011 VANGUARD...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
2008 Nissan Titan Pickup Truck (A51692)
2008 Nissan Titan...
TROYBILT TBE252 GAS POLE EDGER (A51248)
TROYBILT TBE252...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A51247)
UNUSED CFG...
