downslope
- Joined
- Mar 11, 2008
- Messages
- 642
- Location
- NY
- Tractor
- MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I know you can spec an F350 SRW with a 10000 GVW package, not sure about GM; that may be the best way to go if you want to stay at 10K.I couldn't see your attachment but a 1T DW (I assume this means one ton dually) will almost certainly have a GVWR of over 10k. Most newer duallies are in the 13-14k GVWR range. which would put you over the 26k combined if you have have a 16k trailer. We are in the market for a new work truck and I have been doing some shopping over the past few days. Most 3/4 tons I have looked at were 9500-10000 GVWR, 1 ton single rear wheels were around 11,500. I didn't even look at dallies because I need a non CDL driver to be able to pull a 14k GVWR trailer with it.
Quite a few years back you could get 1-ton 3500 duallys with 10,000 GVW. If something like that were still available today I'd buy one in a heartbeat. Much more stable towing platform, and as long as you stay within axle/tire ratings you are legal to go.
