Oil Presusre and Water Temperature Gauge Add-On
   / Oil Presusre and Water Temperature Gauge Add-On
Here is the water temp and oil pressure lines connected to the engine block.
Sent from my iPhone 2.0 using TractorByNet
Sorry about that. Next time I'm on the computer I'll rotate it.
<CGImageProvider 0x15e014a0>
   / Oil Presusre and Water Temperature Gauge Add-On #15
No problem, thanks for posting.
I've decided against mounting the gauges on hood of the tractor... Once they are finally mounted in the "cockpit" I'll post them too, right side up. :D
Jeff
How do you rotate pictures? I have a few that need it. Thanks
The only way I know is to rotate on my pc then re-upload to my message. I have not found a way to do it within TBN.
Finally finished the installation today. I'll get a night photo another time.
50 PSI Oil and 165°F water no load. Matches about the 1/4 mark on the factory gauge.
   / Oil Presusre and Water Temperature Gauge Add-On #20
They look great.
Aren't you worried about hitting them with your knees?
2020 NEW HOLLAND W80C WHEEL LOADER (A52707)
2020 NEW HOLLAND...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A57880)
2000 GMC C7500...
Renaldo GVB63520-B 6 Row Planter (A53317)
Renaldo GVB63520-B...
KUBOTA KX057-5 EXCAVATOR (A52707)
KUBOTA KX057-5...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
