Just bought a bush hog, what to look for??
   / Just bought a bush hog, what to look for?? #1
Bansil
Gold Member
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
Wife just texted me and she bought a bush hog off someone at her work
All I know is it is a 6 ft and worked when parked last year, so what to look for?
good splines on pto?
gearbox lubricated?
no hardened bolts in shear holes?
good bearings?
no major cracks?
Anything else?
Thanks
   / Just bought a bush hog, what to look for?? #2
gearbox lubricated?
good bearings?
no major cracks?
Anything else?
Thanks
Oh, boy! This should be fun to see what you get!:D Sounds like you have the bases covered on what to check. But God only knows what you are getting in the way of a cutter. Might be the bargain of the century, or might be a "pile". Guess time will tell, keep us posted..
   / Just bought a bush hog, what to look for?? #3
What did she pay?
   / Just bought a bush hog, what to look for?? #4
How bent up is 3 point hitch mounts (i.e. how level when mowing)
Any sheet metal bent (i.e. can blades turn fully without striking edge.) Actually, it's optional checking this, you'll know VERY quickly when you spin it up. (BANG! BANG! BANG!) :rolleyes:
Major gouges on blades that require grounding and/or cracks that require replacement?
Can blades rotate/fold back freely at their connection on the stump jumper?
Are blades bent? (i.e. are blades at the same relative height?)
   / Just bought a bush hog, what to look for?? #5
I'm with James. This will be interesting..... :)
   / Just bought a bush hog, what to look for?? #7
Post pics and observations when you get it, then we can go from there.
it was $200, upon seeing it this weekend, it is one of her techs fathers bush hog
they bought a tractor and it came with this, and they do not use it because they also have a belly mower?
I will add pictures once I take some
So far I have gotten some good sdeals on stuff, mainly if you have cash a blank bill of sale and trailer...you can get stuff cheaper :D
:confused2:
must google....
Thanks for video!
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2003 INTERNATIONAL 9200I TANDEM AXLE DAY CAB (A56129)
2003 INTERNATIONAL...
2016 Ford F-550 Enclosed Service Truck (A55852)
2016 Ford F-550...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
