Ladders
   / Ladders #21
Werner heavy duty....great ladders. Little Giant .....great ladders. Depends on use. Little giant very versatile. I would not want to get in a fight with the pretty girl that they use to use for their commercials.......she must have been a body builder in her spare time......yes little giant very heavy.
Werner introduced their own version of the "Little Giant" about 10 seconds after the patent expired on the latter. I bought the 14' model and can say it is very versatile (stair steps, using the pieces as scaffold ends with the supplied brackets and being able to convert it from a step ladder to an extension ladder) and sturdy (which speaks to its downside...weight). I use it when it makes sense to drag that beast around. If you will ever be working around electrical you will want a good quality fiberglass ladder. There are a number of good manufacturers out there and the industry is controlled pretty closely for obvious reasons...never really noticed much difference between brands other than "nifty" innovations...e.g. a few years ago Werner changed the top tray on their step ladders to incorporate a hole that would hold a cordless drill in addition to the holes that hold screw-drivers and the trays to hold screws, etc.
   / Ladders #22
I like the L.G. for a versatile step ladder when needed outside or odd places like on steps and I like it for use with that aluminum platform they sell. It's nice for cutting it at the ceiling when painting in a room. I don't like it as an extension ladder, anywhere or anytime. It is heavy but that equals stability and strength. I'll grab an aluminum or fiberglass step ladder if I working on a smooth floor inside in a heartbeat.
   / Ladders #23
It is like comparing an adjustable wrench to a wrench set. Both have their places.
Bruce
   / Ladders #24
I have a little giant 17'. As others have said they are a little heavy. That is really the only complaint that I have. It is very versatile and stable to climb. I have a 6 & 8' fiberglass ladder also. I mainly use the LG for an extension ladder and for stairs and slopes.
+1
With my job I am on ladders a lot. I carry 4 in and on the truck (5 foot step, Little Giant, 10 foot step, 28 foot extension) and some others at the shop if needed. the LG get used the least but when it is needed, it is nice to have.
Al
   / Ladders
appreciate the replys, my thinking was one general ladder for painting, trim work, etc, would never be more than 10-12' high though. Havent looked at LG type ladders yet but was unaware that they are pretty heavy to tote around.
   / Ladders #26
I guess it kinda depends on what you are primarily going to use the ladder for. I have a 4' step, 6' step, 8' step and a 24' extension ladder. All fiberglass.
   / Ladders #27
Remember your extension ladders are measured fully extended. You don't have to extend it at all if you don't need it (e.g. your 32 ' ladder is a 16' ladder) or you can extend in increments from none to full height. Fiberglass is relatively light, commercial grade aluminum a little heavier. And I would stick with commercial grade (that be orange in fiberglass ladders) because I think they are sturdier and better able to handle the stress of getting moved around. If you go extension, maybe not needed for your planned heights but for longer ladders make sure they make a stabilizer attachment for it. I prefer step ladders because of the top tray and that feeling of balance but for your heights you might find the big ones a bit clumsy to move around. I had a 14' once and that was my experience.
   / Ladders #28
We were taught in the fire department to set up a ladder and stand with your feet between the feet of the ladder, stand up strait and hold your hands-arms out from your body at 90 degrees and you should be able to grip the rung in front of your hands. If not the ladder is ether to steep or not steep enough. Thought I would through that in. Ed
   / Ladders #29
I have a L.G. look-alike and just love it! It looks SO good over in the corner, out of the way, in a place where it will NEVER move. Although it is heavy and relatively expensive, I'll admit, it is totally useless.
Lots of better options out there if one needs a decent, useable ladder. But - I will say, L.G. does have great commercials.
   / Ladders #30
Hardly useless to us. The Werner clone did get used a lot when we built this house and still gets used from time to time when we need more than our 6' step ladder. I think ours can be up to a 14' step ladder. The components can be separated and converted to two scaffold ends with the supplied brackets. It will convert to a tall extension ladder. One leg can be extended differently than the other for working on stairs. Many people have commented already on the weight factor. The other downside is it can pinch.
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2008 Ford F-550 11ft Flatbed Truck (A52377)
2008 Ford F-550...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
