How would you flash a roof against board & batten siding?
   / How would you flash a roof against board & batten siding? #11
If you want one building, make one building; if you want two buildings make two buildings. If you want the addition to be free-standing, give it its own posts and put a couple inches gap between it and the main building and no flashing is required. If you want the addition to be connected to the main building, they have to be connected so they can't move relative to each other, which means the gable wall is holding the weight of the addition roof. If necessary the gable wall needs to be reinforced.
   / How would you flash a roof against board & batten siding? #12
s219;4417150 I really don't want to tie into the corner poles to support the ledger said:
What are your corners made of? I've seen a few that have skimped out with 4x6 for "in line" (not corner) posts, but 99% that I've ever seen are either a 6x6 or 3-2x6 laminated together. The added load of the additional roof could be added to either of the last 2 (posts) I mentioned without any concern.
You've got any other post(s) handled with your thick slab. Nice looking building!
   / How would you flash a roof against board & batten siding? #13
The right way is to take the siding off, add the proper header, addition, then reside it.
My FIL had an addition built on his pole barn by the original pole barn builder, they didn't do it right, kept the siding on, cut the ribs, smashed it in to put a truss against the existing building, it looks terrible
   / How would you flash a roof against board & batten siding? #14
I needed to do a similar flashing job on vertical siding for a deck.
What I did was make a straight cut and lightly pry the siding and proceeded to slide the flashing behind the vertical siding.
It actually worked out much easier than I expected.
I then simply tapped the siding back up tight.
For your roof you might want to simply cut away the amount of the header plate and use metal hangers to attach the rafters, deck and shingle the roof and then slip the flashing behind the upper siding and naturally over the shingles.
Cutting a taper in the flashing will make the sliding in easier.
For maximum attachment you might use suitable lag bolts to attach the header plate to the studs.
I thought I'd give an update on how I ended up doing this.
After thinking it through, I decided it would be overkill to cut a huge hole in the siding for the ledger/header, since it was supported external to the barn, and didn't need to tie into internal framing. So I waited until I had the lean-to roof framed and sheathed, and used an undercut saw (aka, "jamb saw" to a floor installer) to rip a groove through the siding that could take the flashing.
Here's a shot of the saw doing its thing. I set it to cut the bottom of the groove about 1/4" above the sheathing, to account for the thickness of shingles:
The blade was sharp and left a nice crisp cut through the pine siding and battens, perfectly aligned with the roof pitch. I went over each batten and nailed the cut ends down with my brad gun to keep them in place, and made another pass with the saw, raising the blade to widen the groove. These type of saws give very precise control over blade height, so I was able to cut a very nice straight 3/8" groove:
After this, I cleaned up all the sawdust and hit the sawn edges of the siding with some stain to neaten it up:
After the roof shingles were installed, I bent up my flashing and fed it through from inside the barn for a test fit:
Looked good, so I nailed it down, sealing each nail hole with some Henry flashing caulk:
Next up is siding!
   / How would you flash a roof against board & batten siding? #16
Nice clean installation. Congratulations. I've never seen an undercut saw before. I have dozens of different types of saws, but now I now what my next one is going to be!!!!
What do you use it on other then cutting flashing into barns?
It's really intended for flooring install, to undercut door jambs, doors, baseboard trim, etc... Basically, it's a lot faster/easier than how I'd normally under cut a jamb with a hand saw or vibrating saw. It can get down flush if needed, or be adjusted to cut up to about 1" off the floor. Also has a depth gauge to limit depth of cut, so you won't saw into framing (I removed it for the flashing cuts, since I wanted to go clear through the battens and siding boards).
They make a masonry blade for these saws that can be used to undercut brick/etc -- say if you were installing flooring up to a hearth/chimney and wanted to tuck it under. I have only ever used them on wood though, so I can't say how well they work on masonry.
I rented this one for $25/day. Most rental places have them, including Home Depot rental. I think they are around $150-250 to buy new. If you do a lot of flooring installs, it might be worth it.
Me, I was happy that a tool exists that could easily be adapted for this non-traditional flashing job. I always seem to be in a pinch where I can envision the perfect tool, or material, or product, but can never find it. In this case, everything came together perfectly. For me that's like 1 out of 1000 where the magical tool exists....
My other option would have been to use a skill saw, with blade set to an angle, to make the cut before the roof went up. Could have been done from the inside or outside, but it would have taken perfect calculations and super good luck to know that the cut I made beforehand would line up in the right place above the roof shingles. Making the cut after the roof framing and sheathing was up eliminated all of that uncertainty.
   / How would you flash a roof against board & batten siding? #18
Thanks for the update, looks great. And I like that saw also, I'll keep it in mind.
   / How would you flash a roof against board & batten siding? #19
Other than door jambs, have used an older model crain to cut subfloor flush against a wall when replacing a rotten section. Not sure if it was an intended use, but was an efficient and clean cut
   / How would you flash a roof against board & batten siding? #20
Saws | Crain Tools
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
Manac Walking Floor Trailer (A50322)
Manac Walking...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
2017 Harley Davidson Electra Glide (A52377)
2017 Harley...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
