Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,291
I had some help today, these two guys hired me to skid out some logs for them,
I'm cutting in the same woods, so no big deal helping them out,
Here's a few of the logs I skidded out for them, Most of them were 16 to 20 feet long,
Once I had them to the road, they went and got this fork lift to move them,
They were taking them four at a time, but the rear was getting a bit "light" with four on board... lol
Well, that's it for today!
SR
   / Tractors and wood! Show your pics #3,292
SR
Sorry but there is no way those logs are 20,000 lbs and that forklift is more than that. Rear End light - my BS meter was pegging again.
   / Tractors and wood! Show your pics #3,293
Where did he claim they were 20,000 pounds? That load wasn't 20,000 pounds, but that forklift should be able to lift that. My much smaller forklift is rated to lift 6500 pounds at 24" although it can do better. I lifted 2 pallets of concrete blocks at the same time with it.
   / Tractors and wood! Show your pics #3,294
I'm only saying that with two of the logs at the end of the folks and the over head crane also on it, it was some rear end light... I never said the wheels were off the ground, but I did see them lift some when he backed up...
Perhaps you need to work on your reading and comprehension skills some?
SR
   / Tractors and wood! Show your pics #3,296
Can't wait to get this home and try everything out!
Did you get yourself a self-releasing snatch block to use with that winch? It can make things much easier when you need to pull around a corner or avoid damaging a tree along the route of your pull
   / Tractors and wood! Show your pics #3,297
Guys that is a 30k forklift plus all the weight hanging on the back. Wet wood is heavy but that is a beast - which is obviously why he dragged the logs to the road. It would have to be very solid soil for that to go across without sinking without a load.
   / Tractors and wood! Show your pics #3,298
Woods are dry enough to start up again. The bugs aren't far ahead. Already seeing a few.
gg
   / Tractors and wood! Show your pics #3,299
First of all it is NOT a 30K plus forklift, although he does have one quite a bit BIGGER that's rated 26,500...so YOU are now pegging my BS meter...
Secondly, Steve called me last night and said he ran the biggest logs through a log weight calculator and the two biggest logs are just over 4K each... Several of the others went just over 3K...
4+4+3+3 = 14,000 plus and then there's the weight of that heavy SOB crane body/arm that was ALSO on the forks... THEN there's the facts that the two heaviest logs were at the end of the forks...
SO, what is the issue here??? OTHER than creamer hasn't thought this out very well and just wants to break my balls here...
SR
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
Skid steer auger plate (A50322)
Skid steer auger...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
