Best way to get fuel smell out of fuel container caution possible unpopular thoughts
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #11
Metal or plastic? OP really doesn't say.
I'd try ammonia. Ship back with some ammonia and wish you were a mouse on wall of seller when he smells them.
If you put enough ammonia in, if he gets a good enough whiff, good chance he'll keel over in a faint. I've seen it happen. :D
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #12
I would use dish soap and hot water to start with, then perhaps follow up with a steam pressure washer inside (most tractor dealers should have one).
Ammonia should me a good finisher to mask any remaining smells :D
Aaron Z
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #13
Here's another thought. Go to your local fish store and buy activated charcoal. I've had good luck getting a lot of other nasty smells out of containers and even a frig with it. It isn't fast however. The frig took months however it was still being used at the time.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #14
You could always fill it with eggs and let it sit in the sun for a week but then you'd be asking another question.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #15
White vinegar.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #16
His rants on hunting and polyester? Can't help him?
Don't know how it is with gas smell but ammonia sure helps keep the bears out of the garbage although I think Pine Sol works a bit better. I use both just to be safe.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #17
That's a good very good idea, charcoal absorbs a lot. However, the problem is the plastic absorbing the gas, not the gas just floating around on its own. So it might not be as effective. Worth a try though.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #18
My mom smelled up my grandmothers old frig (which was at this time in her basement) by leaving old paint brushes in it and forgetting about them. She called me and I recommended charcoal. It did work but it took time.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #19
I just got a 15 gal spot sprayer and based on my research ammonia is the best thing to clean them between spraying different chemicals - rinse several times to get all liquids out. put in ammonia in 1/2 cup per 2.5 gal or so - let shake to get it on all the surface and let set overnight
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #20
Ok, where did the OP go? All this great help and zip from him?
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X115619 (A57453)
2009 Ford Crown...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
Pickup Instructions (A55272)
Pickup...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
17101 (A55787)
17101 (A55787)
FENCE PANELS (A58214)
