Best way to get fuel smell out of fuel container caution possible unpopular thoughts
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #11
Metal or plastic? OP really doesn't say.
I'd try ammonia. Ship back with some ammonia and wish you were a mouse on wall of seller when he smells them.
If you put enough ammonia in, if he gets a good enough whiff, good chance he'll keel over in a faint. I've seen it happen. :D
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #12
I would use dish soap and hot water to start with, then perhaps follow up with a steam pressure washer inside (most tractor dealers should have one).
Ammonia should me a good finisher to mask any remaining smells :D
Aaron Z
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #13
Here's another thought. Go to your local fish store and buy activated charcoal. I've had good luck getting a lot of other nasty smells out of containers and even a frig with it. It isn't fast however. The frig took months however it was still being used at the time.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #14
You could always fill it with eggs and let it sit in the sun for a week but then you'd be asking another question.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #15
White vinegar.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #16
His rants on hunting and polyester? Can't help him?
Don't know how it is with gas smell but ammonia sure helps keep the bears out of the garbage although I think Pine Sol works a bit better. I use both just to be safe.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #17
That's a good very good idea, charcoal absorbs a lot. However, the problem is the plastic absorbing the gas, not the gas just floating around on its own. So it might not be as effective. Worth a try though.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #18
My mom smelled up my grandmothers old frig (which was at this time in her basement) by leaving old paint brushes in it and forgetting about them. She called me and I recommended charcoal. It did work but it took time.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #19
I just got a 15 gal spot sprayer and based on my research ammonia is the best thing to clean them between spraying different chemicals - rinse several times to get all liquids out. put in ammonia in 1/2 cup per 2.5 gal or so - let shake to get it on all the surface and let set overnight
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #20
Ok, where did the OP go? All this great help and zip from him?
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2022 FORD F-250 (A58214)
2022 FORD F-250...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A52709)
2014 VOLVO A25G...
