Best way to get fuel smell out of fuel container caution possible unpopular thoughts
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #11
Metal or plastic? OP really doesn't say.
I'd try ammonia. Ship back with some ammonia and wish you were a mouse on wall of seller when he smells them.
If you put enough ammonia in, if he gets a good enough whiff, good chance he'll keel over in a faint. I've seen it happen. :D
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #12
I would use dish soap and hot water to start with, then perhaps follow up with a steam pressure washer inside (most tractor dealers should have one).
Ammonia should me a good finisher to mask any remaining smells :D
Aaron Z
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #13
Here's another thought. Go to your local fish store and buy activated charcoal. I've had good luck getting a lot of other nasty smells out of containers and even a frig with it. It isn't fast however. The frig took months however it was still being used at the time.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #14
You could always fill it with eggs and let it sit in the sun for a week but then you'd be asking another question.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #15
White vinegar.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #16
His rants on hunting and polyester? Can't help him?
Don't know how it is with gas smell but ammonia sure helps keep the bears out of the garbage although I think Pine Sol works a bit better. I use both just to be safe.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #17
That's a good very good idea, charcoal absorbs a lot. However, the problem is the plastic absorbing the gas, not the gas just floating around on its own. So it might not be as effective. Worth a try though.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #18
My mom smelled up my grandmothers old frig (which was at this time in her basement) by leaving old paint brushes in it and forgetting about them. She called me and I recommended charcoal. It did work but it took time.
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #19
I just got a 15 gal spot sprayer and based on my research ammonia is the best thing to clean them between spraying different chemicals - rinse several times to get all liquids out. put in ammonia in 1/2 cup per 2.5 gal or so - let shake to get it on all the surface and let set overnight
   / Best way to get fuel smell out of fuel container caution possible unpopular thoughts #20
Ok, where did the OP go? All this great help and zip from him?
IRON FORCE IMPACT SET (A58374)
IRON FORCE IMPACT...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
(3) HAND TRUCK (A52708)
(3) HAND TRUCK...
2014 Chevrolet Tahoe SUV (A55973)
2014 Chevrolet...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
