Patched tires and towing
   / Patched tires and towing #1
daugen
Epic Contributor
New Hope PA
in between now
Just had a good sized nail taken out of the front right tire, Michelin LTX2, 275/60/20 after the TPMS system went off.
30 pounds instead of 40. Slow leak. System worked just like it should, and the Ram dealership in town fixed the tire
for a very reasonable fifteen bucks.
But...I tow a 7000+ pound travel trailer behind my 2015 Ram 1500, and now I have a patched tire. These tires are already
working at capacity. Can I run safely with a patch? I'm sure the stock answer is yes, but have any of you had properly installed
patches fail?
15,000 miles on tire, really don't want to have to use it as a spare, but should I?
thanks
Drew
   / Patched tires and towing #2
I've had tires patched for the exact same reason you did. I've never had a patch fail but I had a serious talk with the senior man at our local tire sales store - Les Schwab tire sales & service. I was fully prepared to replace the patched tire with a new tire but he indicated with the type of patch they used it was not necessary.
I would suggest you contact the local Michelin dealership and have them analyze this situation.
   / Patched tires and towing #3
You have a better chance of something else getting another tire than the patch failing on that one if done properly.
Chris
   / Patched tires and towing #4
Just how did they patch the tire? Did they put a patch on from the inside (sometimes called a "boot") or did they use a "plug" without needing to take the tire off the rim/truck?
Properly done, either method should be fine for continued use - but, they need to have been properly done.
If the tire holds air for the next month with regular use, it should be just fine.
   / Patched tires and towing #5
many times when I replace a tire the old tire could have up to (guessing the most is about 8 to 10 patches in it), but the average is 3 or 4 patches in most any tire,
one day on the pasture pickup I had flats on only 4 tires that day,
a side wall should not be patched, and depended up on, if one needs to some times one can run a tube in a side wall puncture, (but I hate tubes with a passion),
a patch does not dis qualify a tire from service,
and in my recall, I do not think I have ever removed a tire (wore out) from service that did not have a patch, in it,
If properly patched it is a good repair, (if the damage is extensive, it should be retired, a nail or wire, is not usually a type of damage that weakens the tire),
if the tire bulges where the patch is or any where, replace the tire, as usually a belt is damaged,
   / Patched tires and towing #6
Move it off your steer wheel to the rear ...
   / Patched tires and towing #7
I've run plugged/patched tires towing off and on forever...As long as it's done right, no problem.
   / Patched tires and towing #8
I've plugged many a tire on both trailers and truck. Never an issue afterward.
   / Patched tires and towing #9
Here's another good argument starter. Sounds reasonable, but I've always been told that if you're going to have a blowout, it's better to have it on a wheel you can steer than one you can't.
For the OP, don't worry about it. I'm 99% sure your next flat will not be the plug.
   / Patched tires and towing #10
Blowouts are pretty uncommon in my limited experience and it's usually the sidewall that goes. I'd be interested in an expert opinion on this as well. As I understand, in the case of a blowout do NOT jump on the brakes. Control the vehicle and slow normally.
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
207282 (A52708)
207282 (A52708)
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
