Want To Buy: T1 Steel For Box Blade Points
   / Want To Buy: T1 Steel For Box Blade Points #21
Yeah I don't think they are expecting you to be doing a lot of backing with the ripper in the ground but that's not uncommon among equipment that uses them.
thumbnail
In any case I used that image to show one correctly installed with the wear surface on top vs on the under side of the ripper in the linked thread.
Wouldn't want the op to go to the trouble and put them on upside down like this.
134654d1247342142-how-attach-ripper-teeth-cimg0227-jpg
   / Want To Buy: T1 Steel For Box Blade Points #22
I had problems immediately with my landpride gs2584 broke two teeth in less than 20 minutes steel was to hard and snapped right off. I've never had a problem with the h&l teeth gannon uses on my much heavier hydraulic box blade. I ordered factory gannon replacement teeth from messicks And have not had an issue. The shoe on the h&l is actually smaller than the stock landpride but ive never had a problem with my 1350lb gannon box scraper ripping through hard clay road bed
The ground contact strip, 1/4" thick, snaps off. This on complete replacement tine/shoe/point assembly from Agri Supply.
I had to replace assembly when 1 of 5 originals was lost in the woods because I neglected to check the attaching bolt(s) for tightness.
The four Bush Hog (brand) OEM rippers are holding up fine.
Messick's Parts For Bush Hog ROBB - RO600: Bush Hog RO-600 Roll Over Blade Parts Diagrams
Complete shank: $60.89
Point Only: $8.38
Thank you, XRING100
   / Want To Buy: T1 Steel For Box Blade Points #24
Point Only: $8.38
Thank you, XRING100
No problem but jeff9366 recomended the bush hog brand. I'm not sure if they are H&L but are definitely at a cheaper price could be the same and Gannon just has a higher markup
Woods: BB4 SCARIFIER PO, Part # 28765
Part Number 28765
Vendor Woods
Messick's Price $12.64
Stock Quantity 9
Weight 1.10 lbs
Days to Order In stock
Replaces E034, R34
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
KUBOTA U55-5 EXCAVATOR (A51242)
KUBOTA U55-5...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
2015 INTERNATIONAL 4300 BOX TRUCK (A51222)
2015 INTERNATIONAL...
