Creeping EMAXs.Check before you sign.
   / Creeping EMAXs.Check before you sign.
I have an emax22 with backhoe that has 49 hours, the last few hours I used it I noticed it has started creeping.
Post your tractors SN#.Mahindra is really only updating dealer instock units. Retailed units are treated as "Fix as fail" :thumbsup:
   / Creeping EMAXs.Check before you sign. #12
I have a Max28 that does this, I just figured it was the nature of the beast and usually drop my bucket or put the parking break on before I get off the tractor.
I would call your dealer and see if it is still under warranty. If not its fairly simple to adj the creep. :thumbsup:
   / Creeping EMAXs.Check before you sign. #14
My eMax22 Serial number is: 22HRJ01649
You tractor falls into the SN# range for update. Call your dealer to confirm it was done. They can check there records if it was dealer installed or Mahindra if it was Factory installed. :thumbsup:
   / Creeping EMAXs.Check before you sign. #16
Thanks I'll give them a call.
   / Creeping EMAXs.Check before you sign. #19
My emax 25 started creeping forward after about ten hours. I've got 12.5 hours on it now. I don't know what a TIB is, but should I try to adjust the turnbuckle myself or is there some recall/warranty work I need to take it in for? The serial is 25HRJ01724, if that matters at all.
   / Creeping EMAXs.Check before you sign. #20
Call your dealer service department I checked with mine and they said bring it in as it was under recall.
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
(2) Bins of Misc Implement Parts (A50121)
(2) Bins of Misc...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 4x4...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
Moyno Sludge Pump (A50121)
Moyno Sludge Pump...
