I would call your dealer and see if it is still under warranty. If not its fairly simple to adj the creep. :thumbsup:I have a Max28 that does this, I just figured it was the nature of the beast and usually drop my bucket or put the parking break on before I get off the tractor.
Post your tractors SN#.Mahindra is really only updating dealer instock units. Retailed units are treated as "Fix as fail" :thumbsup:
You tractor falls into the SN# range for update. Call your dealer to confirm it was done. They can check there records if it was dealer installed or Mahindra if it was Factory installed. :thumbsup:
Maybe it's a good thing I got a gear tractor.
My emax 25 started creeping forward after about ten hours. I've got 12.5 hours on it now. I don't know what a TIB is, but should I try to adjust the turnbuckle myself or is there some recall/warranty work I need to take it in for? The serial is 25HRJ01724, if that matters at all.
