considering a CK2610hst or CK3510hst
   / considering a CK2610hst or CK3510hst #11
Good points 12Bravo, do you do run a rear mount mower at all ? and on the turbo is there a kit for this ?
thanks
Mike
I run a bush hog and have not had a need for more power......except when I hit a pile of old concrete blocks that I had no idea were there. Lesson learned either mow high the first time or walk the area first.
   / considering a CK2610hst or CK3510hst #12
Ouch! I don't think HP would of made a difference....:shocked:
   / considering a CK2610hst or CK3510hst #13
I have less than 1/4 acre to mow my property is all wooded. So I push mow what little lawn I have, can't help on mowing with 2610.
If you are fine with a 5 foot mower, you should be okay from what I have read and heard. But I don't have first hand knowledge.
   / considering a CK2610hst or CK3510hst #15
Okay so reading some posts here and one said something about the 3510 having a turbo from the factory....... however I can not find this in any Kioti literature. I'm leaning towards the 3510 for the extra HP as I kinda like the idea of having some in reserve. thanks for all the input I am going to go to the dealer tomorrow and look again and try to make a decision.
   / considering a CK2610hst or CK3510hst #17
I don't have a kioti, but HP is not everything. My 28hp Mahindra has all the HP I will ever need. If I put it in low, 4wd, I will always spin the all the tires before I stall out from lack of power.
It's the weight/hp ratio that is more important than HP only.
   / considering a CK2610hst or CK3510hst #18
:thumbsup:
   / considering a CK2610hst or CK3510hst #19
I'd go for the 2610. I had a CK20 with 21hp and it ran a backhoe and a five foot finish mower with no problem at all. Never used a broadcast spreader but I imagine it doesn't use as much power as a mower.
   / considering a CK2610hst or CK3510hst #20
I have a CK 30 and use a 6ft. Finish mower, plenty of power its never bogged on me..I love Kioti's it's really a great Machine.
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
2006 JOHN DEERE 650J XLT CRAWLER DOZER (A52707)
2006 JOHN DEERE...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
Ammco Brake Machine (A55758)
Ammco Brake...
(2) Jet Skis and Trailer (A54865)
(2) Jet Skis and...
