considering a CK2610hst or CK3510hst
   / considering a CK2610hst or CK3510hst #11
Good points 12Bravo, do you do run a rear mount mower at all ? and on the turbo is there a kit for this ?
thanks
Mike
I run a bush hog and have not had a need for more power......except when I hit a pile of old concrete blocks that I had no idea were there. Lesson learned either mow high the first time or walk the area first.
   / considering a CK2610hst or CK3510hst #12
Ouch! I don't think HP would of made a difference....:shocked:
   / considering a CK2610hst or CK3510hst #13
I have less than 1/4 acre to mow my property is all wooded. So I push mow what little lawn I have, can't help on mowing with 2610.
If you are fine with a 5 foot mower, you should be okay from what I have read and heard. But I don't have first hand knowledge.
   / considering a CK2610hst or CK3510hst #15
Okay so reading some posts here and one said something about the 3510 having a turbo from the factory....... however I can not find this in any Kioti literature. I'm leaning towards the 3510 for the extra HP as I kinda like the idea of having some in reserve. thanks for all the input I am going to go to the dealer tomorrow and look again and try to make a decision.
   / considering a CK2610hst or CK3510hst #17
I don't have a kioti, but HP is not everything. My 28hp Mahindra has all the HP I will ever need. If I put it in low, 4wd, I will always spin the all the tires before I stall out from lack of power.
It's the weight/hp ratio that is more important than HP only.
   / considering a CK2610hst or CK3510hst #18
:thumbsup:
   / considering a CK2610hst or CK3510hst #19
I'd go for the 2610. I had a CK20 with 21hp and it ran a backhoe and a five foot finish mower with no problem at all. Never used a broadcast spreader but I imagine it doesn't use as much power as a mower.
   / considering a CK2610hst or CK3510hst #20
I have a CK 30 and use a 6ft. Finish mower, plenty of power its never bogged on me..I love Kioti's it's really a great Machine.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A56129)
2021 MACK GRANITE...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2016 Nissan Altima 2.5 Sedan (A55853)
2016 Nissan Altima...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
