Gannon Box Blade 6 ft on CL
   / Gannon Box Blade 6 ft on CL #1
GoldenCityMuse
Catron County, NM
Cabela's LM 55 HST Cab [like TYM 554]
I see this on my regional CL.
It has the hydraulic rippers. But how hard would it be to make this compatible w/ a cat 1 3PH? I have quick hitch too.
   / Gannon Box Blade 6 ft on CL #2
This is a cat 1-2 setup. The inside 2 slots are for cat 1, and the outside 2 slots are cat 2. You'd need to check with the manufacturer about the quick hitch compatible or if its close to you go measure it. Good looking box blade.
   / Gannon Box Blade 6 ft on CL #4
Well I see the link I tried didn't help much but another picture. :confused3: Go to the Gannon web site.
   / Gannon Box Blade 6 ft on CL #5
I don't believe that it is QH compatible. :( Easy fix though. Cut off the ears on the mast and rotate them forward and weld. That "should" take care of the QH compatible problem. :cool:
   / Gannon Box Blade 6 ft on CL #6
that would be a beast of a box blade..
Thanks for the info guys, I certainly am interested in it.
Asking price is ~$2k. What do you think?
   / Gannon Box Blade 6 ft on CL #8
Price a new one and determine the difference. If a new one is 3k+ - I would say that it's a good deal.
   / Gannon Box Blade 6 ft on CL #9
I have a very similar one from Modern Implements 7 FT with the hinge back, only difference is mine has the manual scarifiers, mine also is a category 2 hitch. I bought CAT 1 to 2 bushings from TSC, and cut them down to where the were flush with the hole on the inner ears. Then I bought CAT 1 pins with the bolt ends, I mounted the pins inwards and bolted them through the first set of ears with grade 8 washers. It is not the preferred method but I haven't had any issues. I will post a pic tomorrow when I get home. I have noticed after about 25 hours one of the pins is bent by about a half inch. But considering all the stuff I push and pull with it I guess a little bending is expected.
   / Gannon Box Blade 6 ft on CL #10
Sorry, but your Modern Implements BB is not similar at all.
To the OP. These are not QH compatible. The top link pin is not forward far enough. The QH will impact the scarifier cylinder or it's fittings/hoses unless modified.
These BBs are a beast. Not familiar with your tractor??? I use a 7' on a 95HP, 10K lb tractor. It handles it well but can still be stalled if scarifiers are dropped into solid dirt.
The 2K price is fair. Not a steal, but not a ripoff either. You need to decide how much you will use it.
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2001 John Deere M665 (A50120)
2001 John Deere...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2012 Cadillac CTS Sedan (A53424)
2012 Cadillac CTS...
2025 Wolverine PFA-11-3300G 48in 3500lbs Hydraulic Adjustable Pallet Forks Skid Steer Attachment (A52378)
2025 Wolverine...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
