Gannon Box Blade 6 ft on CL
   / Gannon Box Blade 6 ft on CL #31
My problem with qh compatibility is shown below i'm pretty sure i could turn the cylinder around if the ears were located down a few more inches. Mine is a new model though
heres the link to the post that i sent to Gannon to have QH compatibility removed from their site
http://www.tractorbynet.com/forums/attachments/304549-gannon-88-hsd-box-scraper-post3710424.html#post3710424
Well, it took m longer to get around to adding pix.
It was pretty large for my little tow dolly, but I managed.
   / Gannon Box Blade 6 ft on CL #33
Nice!! Looks bigger than 6'?
Now let's see some pics with rippers down and box full!
It's 73" outside edge to outside edge, with 1/2" plate steel for the sides, makes it 72" inside dimension.
I can't really use it yet, need real pins.
   / Gannon Box Blade 6 ft on CL #35
Nice! How many remotes do u have? Hydraulic top link a must IMO.... With hyd sidelink is the cats meow..
   / Gannon Box Blade 6 ft on CL #36
Nice, looks to be hardly used.
Thanks, I have one rear remote already plumbed & set up, w/ space for 2 more.
Would like to get a top-N-Tilt, but i got to figure out how to install.
Does it matter which hose goes where? How do I know which side is the power side and which is the return side?
   / Gannon Box Blade 6 ft on CL #38
They are both pressure. You can switch if you don't like the way the handles operate.
   / Gannon Box Blade 6 ft on CL #39
Go to TYM and get your 2nd & 3rd set of rear remotes. Shouldn't be all that hard to install. Actual top & tilt set runs $870 + shipping costs.
Nice find with the Gannon, it will serve you well. :thumbsup:
   / Gannon Box Blade 6 ft on CL #40
Nope, doesn't matter... Only difference is which direction the cylinder moves when u push or pull the valve lever.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
JOB BOX W/ 100K X 20' NYLONG SLINGS (A54757)
JOB BOX W/ 100K X...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
205028 (A52706)
205028 (A52706)
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
