Gannon Box Blade 6 ft on CL
   / Gannon Box Blade 6 ft on CL #11
Thats a pretty descent price my 88" gannon was $3750 plus tax and hoses. As others mentioned its not qh compatible. Possibly if you turned the cylinder around. The top link pin is also about 6-7" higher than a standard qh.
   / Gannon Box Blade 6 ft on CL #12
Looks like a great specimen.
IMO, if u can find a good used Gannon that will fit your tractor and save $1k+, jump on it. I don't see them come up often. Mine is a 78" and only extends abt 3" outside of the tires. Wish it was 84" but at $1.3k I jumped and am so glad i did every time I use it.
   / Gannon Box Blade 6 ft on CL #13
That is a fair price for this box blade. I suspect it is a 7' model not a 6'. It is not quick hitch compatible as is. You can modify it to work for quick hitch as mentioned. I have a similar model for my 4520 and this should be a good match for your new tractor. \
I live in Ruidoso NM and glad to see more folks from our area join TBN.
   / Gannon Box Blade 6 ft on CL #14
I live in Ruidoso NM and glad to see more folks from out area join TBN.
I believe you are right! I count 8 scarifiers on it.
   / Gannon Box Blade 6 ft on CL #15
Are you sure that's a Gannon? It looks identical to a Frontier branded blade I saw.
edit: I see Jenkinsph's blade is labeled Frontier but looks identical to the CL ad blade from the OP. Are Frontier and Gannon the same blades?
Most certainly a Gannon, another pic shows the name.
I may or may not try to convert to Quick Hitch. If it ends up being on most of the time like I think it will, then it probably won't matter so much.
BTW, if you want ot see my tractor, go HERE
   / Gannon Box Blade 6 ft on CL #17
That is not the same blade as steve's. His has a hinged high back.
   / Gannon Box Blade 6 ft on CL #18
I see this on my regional CL.
It has the hydraulic rippers. But how hard would it be to make this compatible w/ a cat 1 3PH? I have quick hitch too.
It is not QH compatible (the lower sidelink ears need to be slightly extended), but you can make it work and if the price is right, snap it up.
   / Gannon Box Blade 6 ft on CL #19
The Frontier's that look like Gannons are made by TuffLine and are QH compatible. However, the TuffLine/Frontier scarifiers are stamped, not forged.
   / Gannon Box Blade 6 ft on CL #20
Recently I think Frontier has switched suppliers for box blades. My box blade was made by Gannon and is a 2004 or 2005 model BB1284 which has the tailgate and weighs 1260 lbs. It has 8 ripper shanks.
2005 Ford Explorer 4X4 SUV (A55758)
2005 Ford Explorer...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 72"...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
