Has anyone seen / know of a front mounted finish mower?
   / Has anyone seen / know of a front mounted finish mower? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Maybe hydraulically powered.
If not, what would be the downside of building one? Thinking about my wife and her having to mow under trees, wondering if there is a better way.. Rear finish means the tractor tires smashed the grass down first. Even mod mount seems to have a tire issue with a couple of friends of mine.
   / Has anyone seen / know of a front mounted finish mower? #3
That's what is on my Grasshopper,
And, it works fantastic!
SR
   / Has anyone seen / know of a front mounted finish mower? #4
   / Has anyone seen / know of a front mounted finish mower? #5
If you are talking on a tractor think you will have a real issue with seeing the mower and what is going on. Also with a front mounted the discharge I think is more likely to be blown back on you. But you are right on the issues with rfm and mid mount. Are not all mowers on golf courses front mounts? A different thought is how about a side mount cutter? Like the old sickle bar mowers or ones used on roads.
   / Has anyone seen / know of a front mounted finish mower? #7
I thought it was an option for the Power Trac:
They are hydraulic
Yeah, I wasn't specific enough....
I have a power-trac 1850 with a front mounted mower (8 foot). Been thinking about getting the wife a real tractor and not her lawn tractor (well, like a MF 1715 or a BX(small) so).
Doing this does not resolve the finish mowing issue (she is in charge of the yard, I am in charge of the acerage). Thought maybe someone had come up with a mower that just attaches to the arms or push mounts on the front of a tractor. Honestly really not sure why this is not just a standard implement. Never understood the belly mount mower. Seems like a design that people just can't shake.
On my PT I can get finsih mower blades but the mowing deck is really not designed for finish work.
Also been considering just a flail on my PT but 6K for an implement, and me suddenly having to do the work she was taking on, makes me ponder.
   / Has anyone seen / know of a front mounted finish mower? #9
I used to use a 60" Swisher pull behind mower on the front of my Kubota RTV to mow my trails through the woods. Worked pretty good.
I saw somewhere a person incorporated a snow blower front link to a mid mount and put it out front.
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A58018)
2007 MACK CTP713...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
17345 (A56859)
17345 (A56859)
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
500BBL WHEELED...
