Winch dump trailer build
   / Winch dump trailer build
what I can think of is something like this, an arm the extends out to help the geometry. ( i tried to make it in white, off the winch pole)
But i dunno. :confused:
   / Winch dump trailer build #12
   / Winch dump trailer build #13
You're on the right track!
   / Winch dump trailer build #14
I dont see how an arm coming off the vertical pole will increase the dump angle, once the scissor arms goes straight, that's it. Maybe lift the trailer to the required angle, make a bigger scissor arm to fit that, then let/make it collapse all the way down, then try to lift it up and see what breaks.
See this is what happens when you didn't spend enough time studying geometry in high school.
   / Winch dump trailer build #15
Make your scissor pieces of 2x4 until you get it right, then copy in steel.
Bruce
   / Winch dump trailer build #17
Taking the bottom of the winch beam and moving the location forward
would tip it's angle to the back some. It still would require some
modification to the scissor. It would allow for a little greater dump angle
without adding height.
   / Winch dump trailer build #18
Could do it like the military trailers. Engage lock, release 2 levers and back up, they have a pivot point in the frame and its dumped mechanically.
   / Winch dump trailer build #19
These military trailers are not dump trailers. The "hinge" polts at the rear of the tongue are not in line, and something has to twist.
The intent was to unfasten the rear of the tongue, and pivot the hitch upwards on the bolts on the front of the box, for compact storage and transportation.
pivot point when dumping, the angled section of part 11:
Folded for shipment:
Manual download:
www.hummerknowledgebase.com/acc/m101a.pdf
Bruce
   / Winch dump trailer build #20
Last fall I bought for cheap a (barely) used DR VersaTrailer which uses a winch to lift. Unfortunately, it also uses an arm on the winch tower so you can lift a heavy object next to the trailer, then swing it over the bed and lower it in. I used that feature exactly once, but it did work well. It makes the whole contraption tall for driving around my plantings. I pull it with a CC garden tractor, which works most of the time. The trailer itself works well and carries weight (cap. 2,000#) well, too.
I like Jeff's MUTS's lift tower, which I think hinges at its bottom fore-and-aft. I'd like to leave my tower and winch, but remove the awkward (and quite high) boom and replace it with a similar pivoting tower post. It's on the to-do list, though not alone.
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
