band saw blade chojce
   / band saw blade chojce #12
   / band saw blade chojce #13
Great pdf file, lots of good info!
Anyone in Canada (Ontario) know of a place other than Princess Auto to get replacement blades?
E.
I'm in BC but these guys have stores in Windsor and Toronto.
Terry
   / band saw blade chojce #14
All you ever wanted to know about band selection
http://www.lenoxtools.com/Guides/LENOX Guide to Band Sawing.pdf
Give techs a call they are very very helpful and knowledgeable
Hope this helps
Sent from my iPhone 5s 64Gb using TractorByNet
Hi ERicher,
That's an awesome gift- thanks, I just read through it, and saved it for reference.
I'll prolly print it out and keep a copy in the shop too, so I can reference it.
A question though, I'd like to cut a piece of black cast iron water pipe about 6" in OD with about 1/8" wall thickness, it looks like the 10-14TPI blade is the best choice, but would you use lube or not?
Anyone else?
Thanks again!!
Thomas
   / band saw blade chojce #15
Thanks Big Barn! That's got a lot more options. almost too many lol. I'll try some out and see what I like.
Physassist - Sorry no answer for you but I'll add to your question: My bandsaw doesn't even have a lube option and I've always wondered if it's worth adding?
It cuts just fine as is, blade doesn't get hot, but of course it's not exactly fast. I'm wondering if I added liquid cooling if I could speed up the cutting and also lengthen the lifespan on the blades?
E.
   / band saw blade chojce #16
E.
Fair is fair, I don't KNOW the answer to your question either, but my reading of the manual Big Barn posted makes it sound like you'd be right, as does what little common sense I still possess.
Thanks anyway,
Thomas
   / band saw blade chojce #17
E.
***WARNING** The following is an expressed OPINION only and not supported by any scientific evidence!
I disabled and removed my liquid coolant system years ago. It now resides on the shelf. I don't miss the mess it made, the clogged screens and not to mention the short shelf life.
I now use a "lube stick" which I find works well for my "less than industrial" setting ( and is also compatible with my 'cut and dry' attitude.
Terry
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 7FGCU25 LP...
John Deere 8360R MFWD Tractor (A53342)
John Deere 8360R...
2023 JOHN DEERE 8R370 LOT NUMBER 220 (A53084)
2023 JOHN DEERE...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
