band saw blade chojce
   / band saw blade chojce #12
   / band saw blade chojce #13
Great pdf file, lots of good info!
Anyone in Canada (Ontario) know of a place other than Princess Auto to get replacement blades?
E.
I'm in BC but these guys have stores in Windsor and Toronto.
Terry
   / band saw blade chojce #14
All you ever wanted to know about band selection
http://www.lenoxtools.com/Guides/LENOX Guide to Band Sawing.pdf
Give techs a call they are very very helpful and knowledgeable
Hope this helps
Sent from my iPhone 5s 64Gb using TractorByNet
Hi ERicher,
That's an awesome gift- thanks, I just read through it, and saved it for reference.
I'll prolly print it out and keep a copy in the shop too, so I can reference it.
A question though, I'd like to cut a piece of black cast iron water pipe about 6" in OD with about 1/8" wall thickness, it looks like the 10-14TPI blade is the best choice, but would you use lube or not?
Anyone else?
Thanks again!!
Thomas
   / band saw blade chojce #15
Thanks Big Barn! That's got a lot more options. almost too many lol. I'll try some out and see what I like.
Physassist - Sorry no answer for you but I'll add to your question: My bandsaw doesn't even have a lube option and I've always wondered if it's worth adding?
It cuts just fine as is, blade doesn't get hot, but of course it's not exactly fast. I'm wondering if I added liquid cooling if I could speed up the cutting and also lengthen the lifespan on the blades?
E.
   / band saw blade chojce #16
E.
Fair is fair, I don't KNOW the answer to your question either, but my reading of the manual Big Barn posted makes it sound like you'd be right, as does what little common sense I still possess.
Thanks anyway,
Thomas
   / band saw blade chojce #17
E.
***WARNING** The following is an expressed OPINION only and not supported by any scientific evidence!
I disabled and removed my liquid coolant system years ago. It now resides on the shelf. I don't miss the mess it made, the clogged screens and not to mention the short shelf life.
I now use a "lube stick" which I find works well for my "less than industrial" setting ( and is also compatible with my 'cut and dry' attitude.
Terry
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
LMC G500-500A LOT NUMBER 232 (A53084)
LMC G500-500A LOT...
JOHN DEERE Q 850 M LOT NUMBER 226 (A53084)
JOHN DEERE Q 850 M...
(3) Goodyear 10R 22.5 Tires (A51573)
(3) Goodyear 10R...
New Long Forks (A53002)
New Long Forks...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
