Draw Knife Recommendation Needed
   / Draw Knife Recommendation Needed #1
Otto Syracuse
Gold Member
Syracuse, NY
JD 4410
I need to peel about 80 black locust logs for fence posts. The posts are recently cut and green.
I am seeing mixed reviews on draw knives, which is the tool I think I need to do this. I don't mind spending $100 for a quality tool, and I believe I could use it for a few other projects around the farm.
Peavey has one for about $60, but several negative reviews on blade and design. I've seen several from Germany or Sweden in the $150+ range. So I'm looking for something in between.
Thanks!
Otto
   / Draw Knife Recommendation Needed #2
Trust me when I say, you want the best draw knife you can get. Grandsfors Burks is a tool you'll hand down for generations and is quite amazing on the productivity side. I not only have this draw knife, but I also have a cheaper one that is no longer used because it was not up to the task. Buy once, cry once or you'll be like me and have two of them.
Gransfors Bruks Log House Drawknife | Drawknives
   / Draw Knife Recommendation Needed #3
Have you considered buying a de-barking attachment for your chainsaw?
Having used draw knives, I don't mind using them if I only have a small job to do, but if I had what you cited ahead of me, I'd absolutely get one of these:
chainsaw debarker - Google Search
Use videos:
Chainsaw Debarker Attachment Chain Saw Sawmill - YouTube
[I think this looked like the best video, but I'm not sure if the tools are that much different from each other]
Chainsaw Log Debarker - YouTube [This one doesn't use your chainsaw's bar, but looks like it's got a narrower cutting path]
custom log peeling machine, log peeler, log debarker, debarker, peeling, debarking - YouTube [This guy made his own, but doesn't appear to be selling them- I think the handle near the cutting head might give you better control, but be more dangerous by bringing the chain closer to you.]
The Log Wizard - The best debarking and smoothing tool! - YouTube [Are you sure this isn't you? His story is similar to yours- but he doesn't demonstrate peeling bark.]
https://www.youtube.com/watch?v=_aMh37jt2i0 [This is from Bailey's online http://www.baileysonline.com/Chains...ts/Chainsaw-Debarkers/Log-Wizard-Debarker.axd, where I first saw the Log Wizard advertised- but they're $20 more than Northern Tool.]
https://www.google.com/url?sa=t&rct...UcjaBCt5tPfDiAhig&sig2=GTxco-rwAwVypWnMQ2DGtg [This one not so much...]
   / Draw Knife Recommendation Needed #4
I have the same one my grandfather used to peel chestnut logs for our cabin -- 1939. It has been sharpened so much that the blade has a bit of a wave in it. I used it to peel locust posts about 20 years ago. They were green and the bark did come off I nice long strips but it was a slightly slimy/sticky job given all the moisture under the bark.
My old timer neighbor said I could have left the bark on -- once they dry it stays on tight for as log as the post lasts.
Conversely, my consulting forester says to let them lay for a year and the bark will flake off just from moving them around.
So I guess these are thoughts to consider but nothing definitive.
   / Draw Knife Recommendation Needed #5
If you sit the locust in the sun in short order the bark will peel off by hand rather easily. At least black locust I have. I have tons of them.
Also, by peeling off I mean it comes off in sheets.
   / Draw Knife Recommendation Needed #6
Oops, I meant to mention that with the locust logs we picked up last summer, which I had stacked in a pile to dry, what Dr. Rod's neighbor and ComancheFlight predicted did happen- the bark came off easily in big pieces, except around any wrinkles and/or knots, where it was more firmly attached.
Unfortunately I got distracted by the power tools and forgot to add that tidbit- anyway, I assumed that you had a more pressing need for the fence posts and wouldn't want to wait for nature to debark them.
That is correct, I'd like these posts in the ground before summers end. Both "experts" I talked to said to remove the bark, it will look better and last longer. That is in line with my thinking and experience.
PA, I like the debarker attachment, looks like it would work really well. I'll look at the other suggestions here too. Spending some time peeling them in the old fashioned way has some allure to it, but the novelty may wear off on log 20 or 21 or so.
   / Draw Knife Recommendation Needed #8
What about a "bark spud" -- that is the tool specifically for this job. I have one made my Peavey and it worked like a charm when I had to peel a couple logs. Still a lot of work though.
   / Draw Knife Recommendation Needed #9
I still have the draw knife I used to peal the 125 LARGE logs used when I built our cabin in Alaska. There is nothing special about it - its a straight, flat draw knife, about 24" wide. The only things that made it easier to use - its easy to keep sharp and its heavy in the extreme. Keeping it sharp is obvious. Heavy is nice because the added weight makes it easy to "pull through" knots, etc on any log. My draw knife made it thru 125 logs, each 22' long with ease. The blade is 14" wide, 3/4" thick & 3 1/2" deep.
I purchased it at a Feed & Seed store in Anchorage. It has no identifying marks on it but it does look hand forged. The fellow that owned the F&S store recommended this knife over the newer "wonder knives" and he was spot on. Just be very careful when using a draw knife - if you straddle the log, the draw knife will cut your knee caps just as easily as the bark.
Its kind of a PITA to stand along side the log when using the knife but you will have fewer accidents.
   / Draw Knife Recommendation Needed #10
I have been told that they won't last long if you don't let them dry out first. Ed
   / Draw Knife Recommendation Needed #11
One other thought. I recall that when peeling the bark off my posts the biggest hassle was when the blade dug into the wood or the bark. It may be one of those counterintuitive things but the job might go easier with a dull blade. The trick is to get it under the bark at the end and then just pull it through -- you aren't really looking to cut anything, more like progressive prying. So you might look around for a used one [there are hundreds on eBay, many under $10] and give it a test run. I've always been surprised at how expensive a draw knife is, much more than any hand tool I can think of.
   / Draw Knife Recommendation Needed #12
I sure bet it would, and Oosik is a better man than i am, although l used to be more hands on than I am now, back when I was younger, stronger, and had more muscles and energy.
Now I can usually also afford to spend a buck or two to save myself from firing up my carpal tunnel and rotator cuff tears- none of which were an issue then- but are arguably a consequence of said activities.
   / Draw Knife Recommendation Needed #13
I've used fresh cut black locust poles and a lot of them started growing...!
   / Draw Knife Recommendation Needed #14
PhysAssist,
No you are wrong - I'm definitely no better than you. Its just that at the location where we built the cabin there was no other way to get the bark off the logs. I should add - these "logs" were standing straight & tall only a week or so before I debarked them.
And perhaps the most important fact - this took place in 1976, 40 years ago.
The safety note is because a friend came to help one weekend and almost completely removed his knee cap with the draw knife. One dirty, sweaty old T-shirt and several wraps of McGuyver tape kept him from bleeding to death until we could drive him to the hospital in Palmer, AK.
   / Draw Knife Recommendation Needed #15
We always just leave the bark on.
   / Draw Knife Recommendation Needed #16
PhysAssist,
Yah, in '76, I prolly could've done 'em by hand too.
I was going to suggest either hard cap knee pads:
Hard Cap Gel Knee Pads
or leg guards:
Used U.S. Military Surplus Shinguards, Black - 36, Military Sporting Goods at Sportsman's Guide
Both of which have saved me a number of times.
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
2417 (A60432)
2417 (A60432)
John Deere 6195R (A60462)
John Deere 6195R...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
