Will I damage a hose if I clamp it shut to do a cylinder leak down test?
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #21
If the cylinder is leaking internally it won't. But if the valve is leaking, it will. It is how you isolate the problem. Some of you wonder why people are not willing to help. Hummm, I wonder? CJ
Typical installations like that use low pressure hose and connections for the drain/overflow. I guess the first indication of a valve problem would be when the drain hose blew apart.
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #22
I guess I should have explained better. Ball valve goes in the cylinder base end or pressure line with a single acting cyl. That works really well on a double acting cylinder also, it is safe and lessens the chance of injury. Sorry should have been more wordy! CJ
   / Will I damage a hose if I clamp it shut to do a cylinder leak down test? #23
Thanks, but I'll keep using my IR gun.
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A57193)
UNUSED SDLANCH...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
UNUSED SDLANCH SDLC2030FT20'X30' ALL STEEL CARPORT (A57193)
UNUSED SDLANCH...
