Tires axle bolts
   / axle bolts #11
I have a 2004 kubota b7510 with a back hoe and bucket. My axle bolts keep loosing up on me. I have tighten them to 108 ft-lbs like the manual says. I drove the tractor just about 1000ft and they loosen up on me. Does anyone have an answer to this? Do i need new axle bolts,lock washers and nuts? Should i use locking nuts instead?
If they loosen in a thousand feet you got serious issues.
Do you mean the axle clamps or the wheel to hub???
   / axle bolts
Thanks for all of replys .I will try the locktite.
   / axle bolts #16
Are you sure they ain't stretching. I would Mark them with a good marker and make sure they ain't stretching. If they are replace
   / axle bolts #18
Maybe I missed something but I remember reading something about rear wheel fasteners would loosen if you used the backhoe and had the wheels off the ground and brake off. At my age who knows what I read!
   / axle bolts #19
sandyc don't know what you read but having the wheels off the ground and using backhoe won't cause the wheels to loosen.
   / axle bolts #20
Ok. I traded in my 2920 and don't have a by. I wonder if I can read that in one of the manuals. Oh well, no problem. Time for my nap to get ready for some snow blowing tomorrow. + 20 inches expected for this storm.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
1336 (A58374)
1336 (A58374)
2013 VOLVO NVL TANDEM AXLE SLEEPER TRUCK (A58017)
2013 VOLVO NVL...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
