Fiziksgeek
I guess I would also mention things like putting thread sealant on the drain bolts for the front axle when you re-install them, and I would also mention you don't need to take off the front wheels for this. It gives you better access, but is not necessary at all.
Another tip which may cause some people issues, depending on the drain pan you use, leave the plug in the fill tube when draining the hydraulic fluid. I now use a pan which looks just like yours, but my old pan had only one small hole on top, and the hydraulic fluid came out so quickly, it overflowed the top of the pan. By leaving the drain plug in, at least initially, it will slow the flow and help prevent a possible mess.
Can't wait to see the second video!
