MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,206
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I'm positive these are moles not voles. I've caught voles and shrews here before but they don't have the big digging feet and claws.
Kevin
That's a mole. You know it.
There's probably some good worms or grubs around your flowers and veggies that they're nosing around for. I've got a few videos of them moving plants around in my garden. I'll have to look for them sometime. Its one of only two or three times I've seen them working in person. The other hundreds were dead in the traps.
So for the Victor out o sight traps, after I've found and active tunnel with the heel stomp and wait for pop up method, I set the trap across the tunnel to see where I need to make the two slits perpendicularly across the tunnel. Then I use a garden trowel to make the slits and press down the area of the tunnel between the two slits. That collapses the tunnel. Then I arm the trap, set the safety, push the scissors into each slit until the pan is resting firmly against the collapsed part of the tunnel. Here's the hair trigger part.... gripping the cocking levers I push the trap deeper until the pan trips the trigger. I then lift up just a bit, reset the trigger on the very edge of the pan and ever so slowly release the cocking arms just until there's enough pressure on the trigger to hold. Then I remove the safety, then I let go of the cocking arms and let them fall to either side. I keep my hands away from the trigger bar. That thing hurts like heck if the trap trips and it flips up and smacks your fingers!
Then the trap is set.
For very soft soil or sand, you can pop-rivet a canning jar lid to the trigger to increase its surface area. I think this increases the chances of it getting tripped before the sand falls away from the trip pan.
I'll bet I averaged 19 out of 20 sets catching a mole with only 1 in 20 false triggers back when I had the original infestation. I was quite proud of those numbers. :laughing:
