Do I need a hitch that distribute. The load to keep my truck from sinking to much.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #11
The tractor is a farm track 555 back tires are loaded about 900lbs between tires. The trailer is a 16' so if I put the bucket on the trailer the back tires will be on the dove tail! A two bottom plow is in the trucks box.
The trailer rating is fine, its just not long enough to allow you to balance the load better.
I'd still check the truck springs for broken leafs. I suspect a broken leaf or two.
If leafs are OK and don't need replacing and you can't get a longer trailer then at the minimum get a WD hitch.
Unsafe to haul that load that way.
I was thinking of adding on the trailer 18 or 20 feet this can be a nice winter project!.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #13
Add to the back not the front! Lol.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #15
Yes, you need a WD hitch and maybe some improvements to the trucks suspension.
Chris
Chris
I looked under the truck and what I saw was 5 leafs no cracks the bottom leaf was sticking out alittle both sides look ok.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #17
For this setup, yes you need a weight distribution hitch. Front end looks like it is getting light. A larger trailer would help, but most trucks per manufacturers recommendations need a WD hitch when towing usually over 5,000 lbs. not sure is it has gone up on newer ones, but I bet that's what yours is.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #19
Doesn't mean they are not getting weak!
Chris
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #20
Ahh- you got no problems. Just load em both an a lowboy.
HOMEMADE 95"X16' DOUBLE AXLE TRAILER (A58375)
HOMEMADE 95"X16'...
BOX BLADE (A58216)
BOX BLADE (A58216)
2014 JLG 6042 TELESCOPIC FORKLIFT (A52709)
2014 JLG 6042...
1970 Dodge Charger R/T (A57148)
1970 Dodge Charger...
2018 Kaufman 20-Ton Equipment Trailer, VIN # 5VGAP2528JL004708 (A57453)
2018 Kaufman...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
