Piston
Elite Member
Okay, wise-@$$ery aside, you need any tractor with a category 2 three point hitch that is narrower than your blade. ......
Once again....you do NOT need a tractor with a category 2 3 point hitch. A category 1 hitch will work just fine.
Sure, a category 2 hitch is typical of a heavy tractor that would put more weight and traction on the ground, but I could easily use that box blade on my cat 1 only tractor. Not to mention a larger tractor will likely be wider than your 6' box blade.
Are you against using the CAT 420 for dirt working and grading purposes? I'm surprised there were no comments on my mention of that in my previous post.
By the way, Kubota has 0% financing for 84 months right now, just in case that changes anything.
Regardless, that is a very nice and capable box blade that will last you a lifetime. It was a good purchase!
