Ford to try their hand at a diesel 1/2 ton?
Status
Not open for further replies.
   / Ford to try their hand at a diesel 1/2 ton? #211
   / Ford to try their hand at a diesel 1/2 ton? #212
How do you think, battery truck would do in this situation.
8 Series Landcruiser 4x4 Deep Water Crossing, NT - YouTube
HS
Batteries seem to have worked underwater for these.
   / Ford to try their hand at a diesel 1/2 ton? #213
   / Ford to try their hand at a diesel 1/2 ton? #215
Well, at least the engine would get cleaned. I'm sure they would use sealed batteries so I doubt there would be much excitement.
Sea water and lead acid batteries = Chlorine Gas which is a problem in an airtight vessel 1200 feet below the surface while trying to be silent .
Last batteries I seen for that application were 2.2volts each and about the size of a 30 gallon barrel but square instead of round. Heavy copper buss bar is bolted between lug to lug to series the bank up to a nominal voltage of 250V. The current capacity is so high that each battery has two negative terminals and two positive terminals. Ventilation of the hydrogen , oxygen and SO2 fumes methods vary with the application. Sometimes a demineralized water addition system is also plumbed in.
   / Ford to try their hand at a diesel 1/2 ton? #216
The green weenies are sure that Star Trek technology is real along with a 50mpg fleet average . That isn't going to happen unless a majority of vehicles all electric . POTUS or not the laws of physics take presidence over human laws.
   / Ford to try their hand at a diesel 1/2 ton? #217
Yup, batteries are heavy. If a Prius battery weights just under 400lbs., I wonder how heavy a 4x4 truck battery would be that has to tow 10K lbs.??? Now if it had a little diesel to power electric motors on all four wheels (like a locomotive engine) then that could be cool. Problem is I don't think it would be a "little" engine. I've seen what the 4WD Tesla needs power wise and you could power a few houses with that kind of wattage!
   / Ford to try their hand at a diesel 1/2 ton? #218
Status
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
RING 2 STARTS HERE @ 9:15 AM (A57192)
RING 2 STARTS HERE...
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
2013 Jeep Grand Cherokee Laredo SUV (A55853)
2013 Jeep Grand...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
