Ford to try their hand at a diesel 1/2 ton?
Status
Not open for further replies.
   / Ford to try their hand at a diesel 1/2 ton? #211
   / Ford to try their hand at a diesel 1/2 ton? #212
How do you think, battery truck would do in this situation.
8 Series Landcruiser 4x4 Deep Water Crossing, NT - YouTube
HS
Batteries seem to have worked underwater for these.
   / Ford to try their hand at a diesel 1/2 ton? #213
   / Ford to try their hand at a diesel 1/2 ton? #215
Well, at least the engine would get cleaned. I'm sure they would use sealed batteries so I doubt there would be much excitement.
Sea water and lead acid batteries = Chlorine Gas which is a problem in an airtight vessel 1200 feet below the surface while trying to be silent .
Last batteries I seen for that application were 2.2volts each and about the size of a 30 gallon barrel but square instead of round. Heavy copper buss bar is bolted between lug to lug to series the bank up to a nominal voltage of 250V. The current capacity is so high that each battery has two negative terminals and two positive terminals. Ventilation of the hydrogen , oxygen and SO2 fumes methods vary with the application. Sometimes a demineralized water addition system is also plumbed in.
   / Ford to try their hand at a diesel 1/2 ton? #216
The green weenies are sure that Star Trek technology is real along with a 50mpg fleet average . That isn't going to happen unless a majority of vehicles all electric . POTUS or not the laws of physics take presidence over human laws.
   / Ford to try their hand at a diesel 1/2 ton? #217
Yup, batteries are heavy. If a Prius battery weights just under 400lbs., I wonder how heavy a 4x4 truck battery would be that has to tow 10K lbs.??? Now if it had a little diesel to power electric motors on all four wheels (like a locomotive engine) then that could be cool. Problem is I don't think it would be a "little" engine. I've seen what the 4WD Tesla needs power wise and you could power a few houses with that kind of wattage!
   / Ford to try their hand at a diesel 1/2 ton? #218
Status
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
1997 Caterpillar D3C Series III LGP Crawler Tractor Dozer (A55851)
1997 Caterpillar...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A57024)
1992 Talbert 70...
2025 Newrick JC25 Mini Wheel Loader Skid Steer (A55851)
2025 Newrick JC25...
