buickanddeere
Super Member
Could consider measuring the journals and bearings with a mic plus using plastic gauge to obtain before and after numbers. If the journals are out of round a session on the crank grinder will be required.
Could be cam bearings bleeding the pressure away as bad or worse than main & rod bearings.
