sickle bar mowers love them or hate them?
   / sickle bar mowers love them or hate them? #21
Sickle mowers do better if the bar is raised above the old dead grass cuttings and rat nests. Also, adjust the tractor toplink longer to pitch the leading cutting edge upward. These mowers were designed to cut a hay field. Then it was raked into a windrow and baled. The following cuts on the same clean field would not have mowing impediments to clog the sickle. When I was a kid, I clipped pastures with a "clipping wheel" attached the the end of the sickle. This allowed me to cut 4-5" above the junk that would normally clog the mower. Ken Sweet
   / sickle bar mowers love them or hate them? #22
Around here, fire ant hills and sickle bars are a bad combination.
   / sickle bar mowers love them or hate them? #25
An 8 inch mound is not uncommon, especially if it has rained recently.
If they were very prolific, they sure would play havoc with any mower's cutting edges. I have had disc mower customers say when the hit one, it made a big cloud of dust. Thankfully, we only have ground hog mounds and rocks to contend with. Ken Sweet
   / sickle bar mowers love them or hate them? #26
I have 2 rotary cutters, 1 flail mower and 1 sickle mower. I use them all. For the money, nothing can replace a sickle mower.
   / sickle bar mowers love them or hate them? #27
I have a BEFCO 7' sickle mower that I bought new. I tried to find a good used one but gave up. I use the sickle mower mostly for a/ mowing around a pond bank and b/ in its 90-degree up position, mowing the sides of roads and trails. In the 90-degree up position mowing applications, it saves me a huge amount of time, although it took a little seat time to get comfortable with hearing those blades churning so close to you. For my applications, the sickle mower works great. But because I don't have and will never have a lot of hours of use for the sickle mower, it probably wasn't cost-justified. The one maintenance issue I had is that the so-called conic bolts, which anchor the operating arms that are attached to the sickle blades, loosened and came all the way out. It was a real chore to get them replaced, plus they were very expensive when bought from BEFCO. I was already accustomed to tightening the conic bolts frequently, but now I make doubly sure every time I hook up the mower to tighten the conic bolts with a torque wrench.
The one thing I would for sure do differently is buy a 9' sickle mower. I could use the extra 2' when mowing around the pond bank and also it would be better to be able to trim the tree-limb overhang on the roads a little higher.
   / sickle bar mowers love them or hate them? #28
We have a 7 Ft International 1300 beltdrive sickle mower that we use on the farm for mowing under electric fences, pond dams, creek bank, trails and along the county road right of way. The weed eater would do most of what I use the sickle mower for, however, I am not as young as I used to be and I had rather be in the tractor seat than on the ground where the Copperheads, ticks, bees and chiggers call home. Ken Sweet
   / sickle bar mowers love them or hate them? #29
Quote! "The one maintenance issue I had is that the so-called conic bolts, which anchor the operating arms that are attached to the sickle blades, loosened and came all the way out. It was a real chore to get them replaced, plus they were very expensive when bought from BEFCO. I was already accustomed to tightening the conic bolts frequently, but now I make doubly sure every time I hook up the mower to tighten the conic bolts with a torque wrench." End quote!
Just curious, why don't you use a blue thread locker on the conic bolts. Blue can be loosened with brute strength, Red on the other hand will have to have heat to be removed. I do not have any experience with sickle mowers, but I do with thread lockers.
   / sickle bar mowers love them or hate them? #30
I got my #9W for $175.00, and found a #9 for the same price. Bought the #9 for parts. Got a manual and started fine tuning it. After a little trial and error operating it, I can actually mow hay pretty good. Here's a video of it in a small patch of cereal rye, although you can barely see the inner shoe. The rye was drilled heavy (150#/acre) and lodged with a bunch of grass. Later baled it for bedding straw for a neighbors chicken house. Listen to it, sounds like a well oiled machine.
#9WMower - YouTube
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2020 CATERPILLAR 320 GC EXCAVATOR (A60429)
2020 CATERPILLAR...
207270 (A52708)
207270 (A52708)
2004 JOHN DEERE 650H LGP CRAWLER DOZER (A60429)
2004 JOHN DEERE...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
