Any reason to NOT get the wider trailer?
   / Any reason to NOT get the wider trailer? #1
Schneeky
Hey guys. I'm pullin the trigger on a new 10k/8k payload trailer to move the l'il Mahindra and implements this coming week. Lookin at the one linked which is a "drive over" fender setup or another that has "regular" fenders. Question is are there are any negatives to going with a 8.5' wide vs 7'? Gonna prolly be doing this Monday or Tuesday. Got hunt club workdays this weekend. Thanks!! d:^) :cool:
Trailer on CL
   / Any reason to NOT get the wider trailer? #2
The only thing going is more $$$83 wide is good enough for my tractor
   / Any reason to NOT get the wider trailer? #3
I don't think that has the payload you said you wanted?
   / Any reason to NOT get the wider trailer? #4
If I had to do over I would get the wider deck over tires. Just so that I could load other things from the side over the wheels. I actually uses the trailer more now for hauling pallets of block, shingles and the like. Wheels get in the way.:2cents: It is a nice looking trailer
   / Any reason to NOT get the wider trailer? #5
Double check to make sure it has brakes on both axles. The ad is misleading, says a pair of brakes on 5200 lb axle.
The wider trailer can hold larger implements or 2 pallets side by side easier than a narrow trailer. Drive over fenders are stronger than regular and don't dent up as easy. 20' bed length is nice to have. Is 7800 lb payload enough? Is your Mahindra and implements you may carry under that amount?
The payload is listed as 7800#'s which is gracious plenty for my needs I think. I just rounded up to 8k#'s. The 3016 with FEL and BH is only 4510#'s. I wanted plenty of buffer and some overhead for throwin extra crap on with the tractor.
I think I had asked the guy about brakes on both axles and he had said it did have that. I'll be sure to double check before I make the 3 hour jog up there, tho'.
I've seen references to "never adjust" type brakes. Are there any brake types or trailer mfg's to just avoid completely?
I'd checked with a local dealer who carried Hudson. But they were $1k over the other offerings. Wasn't sure if there was a good reason or just a name thing goin on there.
Thanks for the responses, fellas.. d:^) :cool:
   / Any reason to NOT get the wider trailer? #7
That is a good deal. I would take this wide low boy any day of the week vs a deck over. I had one and never really liked it.
Only issue I see with that trailer is the tongue jack placement. It's will hit most tailgates. I always order my customers trailers with it set back 18"
Chris
Only if you have to back it into an 8' wide spot.
Thankya, newbury.. Thankyavery much. <~~~Done in my best Elvis voice. :D
Diamondpilot- One of my concerns with it is the ground clearance. This trailer will be spending some time at the hunt club on the two-tracks. It ain't really "off-road", but there is some up-n-down. Not sure if the "lowness" will cause some azz draggin'. :(
And the roads gettin there ain't exactly overly wide, either. :rolleyes: But I only have 10 or so miles of those.
Although they are regularly terrorized by chicken & logging trucks. :eek: d:^) Jake..
   / Any reason to NOT get the wider trailer? #10
<snip>
That's what I was getting at - if the extra 1.5 feet of width was restrictive a narrower trailer might be needed.
And is a chicken truck anything like a chicken tractor? :)
   / Any reason to NOT get the wider trailer? #11
As posted earlier, I would favor a true deckover, no raised fenders, totally flat deck.
Otherwise, I doubt you'll notice the width difference from one to the other.
   / Any reason to NOT get the wider trailer? #12
I also favor this type of ramps, with a leg built in that functions when ramps fold down.
The reason to avoid fenders is also obvious in this picture.
Hehehe. Walp, it's where they end up between the "chicken house" and the "chicken plant". I guess I coulda said "livestock truck" cause the "hog trucks" are just as bad and way smellier.
The logging trucks are still the most dread sight to see in the opposing lane. :eek::D
dieselcrawler- That's a good point about the deck-over. I had one of those before and the height of it always made me a bit antsy. Prolly no real legit reason for that, just my own perception of the set up being top heavy. That said, I'm pullin a pretty small rig now. So I'll hafta consider one for sure. Looks like worries of draggin the tail would be moot. And that's one of the things I didn't like about the trailer linked.The ramps are stored under the back of the deck. The guy that ran the trailer place said he'd had some guys cut those off and re-weld them back up on the tongue or some such. :cool: d;^) Jake..
   / Any reason to NOT get the wider trailer? #14
My old 18' low boy had the exact same style of ramps and holders. It was never a issue. That trailer sat low, only 14" from the ground to deck. I can not think of a single time they dragged.
Chris
   / Any reason to NOT get the wider trailer? #15
I got a deck over sort of like yours and I think the worrisome feeling of being high off the ground was overcome pretty fast when the usefulness of using the whole bed came into play. I haul wood and it is nice not having to worry about fenders. Otherwise I would have to drag logs off the back. My fenders would have been smashed long ago.
I do pay attention to little hills and dips that the trailer may dig into. I try to keep it on more level ground.
   / Any reason to NOT get the wider trailer? #16
At work, we have at least 4 car hauler type trailers, with the style ramps like on my deckover trailer. They are used by many different employees, and the fenders are beat to he!!. The fenders tend to be more in the way than the lower deck hight is of any help.
As to width vs deck hight, even my deckover is lower than any semi truck flat trailer, with a wheel track nearly as wide. I've had some tall and heavy loads, and never had a 'top heavy' worry, as the overall weight increases, you tend to slow down on that account long before the top heavy issue.
   / Any reason to NOT get the wider trailer? #17
yes, there's sometimes reason to get a narrow and low trailer. The low is pretty obvious, the narrow is if you have tight turns or pull in cities/suburbs a lot. I just bought another trailer (big tex) for those reasons.
For what I use it for, my big deckover is awkward.
If I were in the country all the time, I'd go as big and wide as possible. I still think lower is better though, I wouldn't sell my deckover, but I wouldn't buy another one either. I don't find that width does anything for me in practice.
Thanks much for the replies and opinions, fellas. :thumbsup:
Deere Dude- If I was haulin stuff like that I'd definitely want the flat deck! But I really don't see it happenin in my current situation. The tractor with mebbe an extra implement or two, some pallets on occasion. Prolly about the height of it. :)
dieselcrawler- Agreed that I see a lot of the regular fendered trailers with the fenders pretty beat up. That's why I was looking at the drive over fenders. They seem to be lower than the standard fenders and way more sturdy. The only one using this trailer's gonna be the one who paid for it! Employees are tough on gear they don't have any skin in buying or maintaining. :mad:
Charlesaf3- I rarely go into a city. Much less one with suburbs. It's pretty much country 2 lane highways and interstate. The only secondary roads to deal with are right up at the club and the aforementioned logging trucks have no problem flying around those. :D So I reckon my bitty trailer should be OK.
   / Any reason to NOT get the wider trailer? #19
When I saw my first 8 1/2 foot wide utility trailer,,, I soon asked a state police officer about it, pertaining to the legality of the width.
His response, now, about 15 years ago,,, was that 8 1/2 foot trailers were only allowed on certain categories of roads.
Such a trailer could not be used on typical rural roads,,,
Hmmmmm,,, I wonder if this is still true??:confused2:
   / Any reason to NOT get the wider trailer? #20
My only complaint with my 8.5' wide similar built trailer is the extra distance I have to stretch to tie down a narrow load.
Kubota BX25D (A53317)
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
DEUTZ MARATHON...
2015 FECON FMX50 HYD MULCHING HEAD (A60429)
2015 FECON FMX50...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
