Opening up land for a garden and orchard
   / Opening up land for a garden and orchard
A day settling. The roots seem to be poking through more.
Options:
1) hit it with a landscaper rake and try and pull some of the roots out. Then depending on the surface, another pass with the tiller
2) hit it a few more times with the tiller, hoping to chop the roots up.
   / Opening up land for a garden and orchard #32
How about,,,,
3) Pick up the rocks,, then chop the roots with a bush hog,,,,
:thumbsup:
It still looks good that you have a lot of the roots on top,
rather than under ground, getting ready to sprout in the spring,,,
How about,,,,
:thumbsup:
Mmmm. I had not considered the bushhog.
I wonder how far the rear wheel will sink? Might make setting the depth interesting. =]
More time consuming than the landscaper rake, but I like leaving the root material in there to breakdown if I can.
My single row planter arrived. I got it assembled and tested the seed plate for peas with the cover crop seed I got. Oats and peas. Worked well.
I still need to take the landscaper rake to it I think. Those roots are just overwhelming.
Looking towards the garden. Its still behind some brush from where I am. Orchard will be straight ahead and a pond (maybe...) off to the left.
Another pic from a slightly different angle.
Had a little time this AM before I had to do some other things...
Set the rake at an angle.
After 2 passes (mostly, only 1 pass on the left side)
Slowly pulling the roots and larger rocks out.
Im going to take all the leftover root and dirt and put it into the compost pile. I don't want to waste good organic material and dirt. It'll get incorporated back in at some point.
After 2 more passes
I had someone that wanted to help...
I think I'm finally ready to plant.
I stepped off a section for the garlic. The rest will get oats&field peas planted as cover crop.
   / Opening up land for a garden and orchard #38
You could not want a better helper. I would not with a mower but with slow plows have had grandson ride my left knee a few hours or nothing behind the tractor but him just learning to drive.
Tractor was not in motion. I cant keep that kid off the tractor. Ive taken him on my lap before around the field or whatever, but never with implements going. Just a ride. They have many years ahead to get seat time. =]
I got a bunch of rows of oats&field peas planted in the main field.
Front section in the bottom right here is stepped off for garlic and spinach.
I still haven't done anything with the side field. I might try rye in that one.
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2020 Terex RL4 Towable Light Tower (A53421)
2020 Terex RL4...
