Opening up land for a garden and orchard
   / Opening up land for a garden and orchard
A day settling. The roots seem to be poking through more.
Options:
1) hit it with a landscaper rake and try and pull some of the roots out. Then depending on the surface, another pass with the tiller
2) hit it a few more times with the tiller, hoping to chop the roots up.
   / Opening up land for a garden and orchard #32
How about,,,,
3) Pick up the rocks,, then chop the roots with a bush hog,,,,
:thumbsup:
It still looks good that you have a lot of the roots on top,
rather than under ground, getting ready to sprout in the spring,,,
How about,,,,
:thumbsup:
Mmmm. I had not considered the bushhog.
I wonder how far the rear wheel will sink? Might make setting the depth interesting. =]
More time consuming than the landscaper rake, but I like leaving the root material in there to breakdown if I can.
My single row planter arrived. I got it assembled and tested the seed plate for peas with the cover crop seed I got. Oats and peas. Worked well.
I still need to take the landscaper rake to it I think. Those roots are just overwhelming.
Looking towards the garden. Its still behind some brush from where I am. Orchard will be straight ahead and a pond (maybe...) off to the left.
Another pic from a slightly different angle.
Had a little time this AM before I had to do some other things...
Set the rake at an angle.
After 2 passes (mostly, only 1 pass on the left side)
Slowly pulling the roots and larger rocks out.
Im going to take all the leftover root and dirt and put it into the compost pile. I don't want to waste good organic material and dirt. It'll get incorporated back in at some point.
After 2 more passes
I had someone that wanted to help...
I think I'm finally ready to plant.
I stepped off a section for the garlic. The rest will get oats&field peas planted as cover crop.
   / Opening up land for a garden and orchard #38
You could not want a better helper. I would not with a mower but with slow plows have had grandson ride my left knee a few hours or nothing behind the tractor but him just learning to drive.
Tractor was not in motion. I cant keep that kid off the tractor. Ive taken him on my lap before around the field or whatever, but never with implements going. Just a ride. They have many years ahead to get seat time. =]
I got a bunch of rows of oats&field peas planted in the main field.
Front section in the bottom right here is stepped off for garlic and spinach.
I still haven't done anything with the side field. I might try rye in that one.
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
