Do you have issues with your new Ford SuperDuty?
   / Do you have issues with your new Ford SuperDuty? #101
Couple probs we are having, is a piece of foam collecting road salt and corroding the fender and the quarter panels. most comment that they cant see over the hood,, Plowing would be an issue as a result, Someone tried pressure washing one, and blew a big section of paint off, and the metal tears easily if scratched. Few shops are setup for working on aluminum. and they doubt a frame can be repaired,,
   / Do you have issues with your new Ford SuperDuty? #102
The frame is not aluminum.
   / Do you have issues with your new Ford SuperDuty? #103
A gooseneck hitch is stronger.
This. ^^^
For pickups 5th wheels are primarily used for towing campers, not tandem dual equipment trailers which typically have a gooseneck hitch. If you look at how a gooseneck hitch is bolted right to the frame it's very solid IMO.
2012 MACK GU713 (A58214)
2012 MACK GU713...
Pig Statue (A57149)
Pig Statue (A57149)
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
MISC TIRES (A54757)
MISC TIRES (A54757)
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
LandHonor DH-22-72W 84in Disc Harrow Tractor Attachment (A56857)
LandHonor...
