Do you have issues with your new Ford SuperDuty?
   / Do you have issues with your new Ford SuperDuty? #101
Couple probs we are having, is a piece of foam collecting road salt and corroding the fender and the quarter panels. most comment that they cant see over the hood,, Plowing would be an issue as a result, Someone tried pressure washing one, and blew a big section of paint off, and the metal tears easily if scratched. Few shops are setup for working on aluminum. and they doubt a frame can be repaired,,
   / Do you have issues with your new Ford SuperDuty? #102
The frame is not aluminum.
   / Do you have issues with your new Ford SuperDuty? #103
A gooseneck hitch is stronger.
This. ^^^
For pickups 5th wheels are primarily used for towing campers, not tandem dual equipment trailers which typically have a gooseneck hitch. If you look at how a gooseneck hitch is bolted right to the frame it's very solid IMO.
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2013 International PayStar 5900i Heavy Haul Truck, VIN # 1HSXYSJT8DJ321464 (A57453)
2013 International...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A58375)
UNUSED CFG...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2022 Horizon (A55973)
