Welding Cast Iron to regular steel
   / Welding Cast Iron to regular steel
The one note is that what I am welding is a bearing. Not sure about preheating or any of the brazing methods as I am concerned about heat.
   / Welding Cast Iron to regular steel #12
What about welding studs/round bar on your steel piece and bolting the flange block on or leaving the stud/round bar just high enough a flat flasher could be put over it and welded to hold the flange block on?
   / Welding Cast Iron to regular steel #13
The bearing you linked to comes apart. remove the bearing from the housing before you weld.
   / Welding Cast Iron to regular steel #15
If it's like most it removes from the back, if the housing is being mounted without full access to the mounting side you have no way to get the bearing installed.
   / Welding Cast Iron to regular steel #16
7018 bottom of the bucket. 309Lsi better, 312 stainless best. If tensile is no object, ( 25K psi ) Silicon Bronze.
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
2020 Club Car Onward HP Li ION Electric Cart. (A53424)
2020 Club Car...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
