Welding Cast Iron to regular steel
   / Welding Cast Iron to regular steel
The one note is that what I am welding is a bearing. Not sure about preheating or any of the brazing methods as I am concerned about heat.
   / Welding Cast Iron to regular steel #12
What about welding studs/round bar on your steel piece and bolting the flange block on or leaving the stud/round bar just high enough a flat flasher could be put over it and welded to hold the flange block on?
   / Welding Cast Iron to regular steel #13
The bearing you linked to comes apart. remove the bearing from the housing before you weld.
   / Welding Cast Iron to regular steel #15
If it's like most it removes from the back, if the housing is being mounted without full access to the mounting side you have no way to get the bearing installed.
   / Welding Cast Iron to regular steel #16
7018 bottom of the bucket. 309Lsi better, 312 stainless best. If tensile is no object, ( 25K psi ) Silicon Bronze.
2024 Frontier FL1061S Hydraulic Flail Mower (A55314)
2024 Frontier...
2024 Schulte 5026 Batwing Rotary Cutter (A55314)
2024 Schulte 5026...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
Krause Dominator 4850-18ft (A57024)
Krause Dominator...
Case-IH 370 Steiger (A53314)
Case-IH 370...
