Welding Cast Iron to regular steel
   / Welding Cast Iron to regular steel
The one note is that what I am welding is a bearing. Not sure about preheating or any of the brazing methods as I am concerned about heat.
   / Welding Cast Iron to regular steel #12
What about welding studs/round bar on your steel piece and bolting the flange block on or leaving the stud/round bar just high enough a flat flasher could be put over it and welded to hold the flange block on?
   / Welding Cast Iron to regular steel #13
The bearing you linked to comes apart. remove the bearing from the housing before you weld.
   / Welding Cast Iron to regular steel #15
If it's like most it removes from the back, if the housing is being mounted without full access to the mounting side you have no way to get the bearing installed.
   / Welding Cast Iron to regular steel #16
7018 bottom of the bucket. 309Lsi better, 312 stainless best. If tensile is no object, ( 25K psi ) Silicon Bronze.
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2017 John Deere 2305 Tractor - 575 Hours (A55314)
2017 John Deere...
