John Deere 2750 3pt won't lift
   / John Deere 2750 3pt won't lift #21
Determine if valve is free to move in housing IE not stuck open.
I can push on the valve and feel the spring tension, can't get at it to pull it out without a magnet though. Should the spring pressure be strong enough to push the valve out?
   / John Deere 2750 3pt won't lift #23
I think spring should push valve out. Maybe jd110 will reply.
   / John Deere 2750 3pt won't lift #24
Maybe that is the root of the problem, either spring too weak or broken, or some sludge restricting movement.
That is if I get the picture of what is happening. Wish you good luck with the fix.
I can push the valve in with my finger, and it returns by the spring pressure, but I don't know how much spring pressure there should be, in my mind the spring should push the valve out of the hole and it should require a little bit of effort pushing on the valve with the plug to get the plug threaded, if you know what I mean.
LX046640_______UN11MAR05.gifLX046640_______UN11MAR05.gifThis is what my manual is Calling the flow control from valve, part #14.
But when I look it up on the John Deere parts website, it's showing the flow control valve as being down near the Hydraulic filter.
   / John Deere 2750 3pt won't lift #27
I'm sorry for confusing you but Jd added that valve on later utility tractors and I was unaware of it until now, The valve in photo down on RH side of trans case by hyd filter is the one I was referring to.
OK, problem. Is I've also got that housing down on the side of transmission, so there is a flow control valve down there, and that's what the John Deere parts website lists as the flow control valve. So which one should I be looking at?
   / John Deere 2750 3pt won't lift #29
1st remove spool valve in your photo,install plug,start engine & see if 3 pt raises.
Off topic, but when I was jacking the cab up, I broke the differential lock shaft. Would it be safe to use the tractor until my replacement arrives, or will I damage something internally?
(APPROX 50) 2" X 2" X 98" TUBING (A51247)
(APPROX 50) 2" X...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2017 SANY SY365C LC EXCAVATOR (A51246)
2017 SANY SY365C...
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
