Everlast Welders - Welders and Plasma Cutters by Everlast
   / Everlast Welders - Welders and Plasma Cutters by Everlast #741
   / Everlast Welders - Welders and Plasma Cutters by Everlast #742
Mark, Can you PM me a price on a Powertig 210 EXT.
Tim
I sent you a pm Tim. Thanks.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #744
I have to weld 1/2" or maybe 5/8" Cat I ears on this 10' grader I bought a couple weeks ago (see pic below).
For those that know, would you recommend the Everlast PowerArc 200ST or the PowerArc 300ST?
And what the heck does "IGBT" mean anyway? Is that some gay lesbian thing? :)
Either would do it, but you might need the 300 after you use that behind your Kubota for a few minutes. That blade would be hard on a 100 Hp tractor.
But seriously, either would work. But I'd probably go with the 300 if you expect to do much welding like that.
Insulated Gate Bi-Polar Transistor.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #747
Looking at the Everlast 250EX, it looks like it comes with a 18 series water-cooled torch? Is that right? No air cooled torch?
Tim,
You are right. But that is also the issue at the same time. (I pm'd you about it). 250 amps of power requires watercooling. The PowerTIG 210EXT comes with two torches, both air cooled.
If you are looking at both and weighing the pros and cons, keep in mind that a 200 amp machine (give or take) is all that you are going to need if you don't want to spring for the water cooler, or intend to build your own (or have one already). Of course, you can adapt it so you have a loss type system (water hose in and a drain hose out to your flower bed.) (Did I use too many parenthesis?)
   / Everlast Welders - Welders and Plasma Cutters by Everlast #749
Thanks Mark, I just responded to your PM.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #750
I just sent you another PM
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
MILWAUKEE 52" HIGH CAPACITY MOBILE WORKBENCH (A51248)
MILWAUKEE 52" HIGH...
Fire Truck (A51692)
Fire Truck (A51692)
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
JOHN DEERE CP690 LOT NUMBER 217 (A53084)
JOHN DEERE CP690...
MTM CHORE MASTER 2400 PSI PRESSURE WASHER (A51248)
MTM CHORE MASTER...
