Well Pump Wiring - Where to Buy?
   / Well Pump Wiring - Where to Buy? #1
Pettrix
High Desert Southwest
Trying to locate a good online source for well pump wiring. I need 8-gauge, 4 cable, double insulated/direct burial cable.
Also, when splicing the wiring ABOVE ground, are butt connectors and heat shrink tubing OK to use on 230V lines?
I am familiar with 12V DC on vehicles where butt connectors are used but is that OK on AC high-voltage?
   / Well Pump Wiring - Where to Buy? #4
WesBell Wire & Cable is a good supplier with reasonable prices. They should have what you need.
You can use adhesive heat shrink to make waterproof splices.
   / Well Pump Wiring - Where to Buy? #5
THHN THWN is all in one round black cover and can be found at HD. And yes butt splice and heat shrinks are fine.
   / Well Pump Wiring - Where to Buy? #9
The submersible wire is not rated for direct burial. It would probably work OK if you protected it in PVC conduit, but check your local codes.
A waterproof junction box located above ground at the well would probably be a better solution than a buried splice.
   / Well Pump Wiring - Where to Buy? #10
If you have a professional quality crimping tool, butt connectors would be OK, but filled wire nuts are the way to go for an excellent mechanical and electrical connection without the expense of the crimper.
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
