got a water well problem
   / got a water well problem
Quote Valveman, As long as the max pressure of the pump is less than 150 psi, the CSV125 will work fine.
The pump is 1hp with a 40-60 pressure switch. Where would the psi be measured, am I missing something? Will I have to measure PSI somehow somewhere?
And with a 40-60 pressure switch would I use a CSV125 60psi? also I can install it horizontal?
Richard
   / got a water well problem #22
Richard
The back pressure depends on the pump and the static water level. A 1HP, 10 GPM pump with a static water level of 32' will have a back pressure of 150 PSI. A 1HP, 7 GPM pump would need the static water level to be at least 192' deep to stay below the 150 PSI back pressure needed for the CSV125.
The CSV1A can take a lot more back pressure than the CSV125. Just let me know the GPM of your 1HP pump and the static water level and I will figure it for you.
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
