Are Automakers This Stupid?
   / Are Automakers This Stupid? #2
Sounds kind of like Lawyers. The worse the problem, the more income derived from it. So, make the problem bigger.
The moto from my ,polluting generation, was that there was no replacement for displacement.
   / Are Automakers This Stupid? #3
Are Automakers This Stupid? <<<<<Only when it come's to airbags, oil filter location and when the timing belt breaks, it breaks the engine.......
"(According to a Reuters report, closer emissions testing scrutiny in the wake of the Volkswagen diesel emissions cheating scandal, reveals that downsized engines, both gas and diesel, are bigger polluters than previously thought.") <<<<<<<<Who would of thought, I guess sometimes, bigger is better....
   / Are Automakers This Stupid? #4
Fortunately, I was able to learn to read in the first grade. The article clearly states: "At higher load and throttle levels than standardized emissions lab testing". The Federal Emissions test is the only task that must be met. And fuel economy is NOT the goal. In fact, fuel is added downstream of the combustion chambers to heat the main and then the pup converters.
A turbo increases the effective compression ratio by jambing in more air than a natually aspirated engine. Same principle as a supercharger (mechanical turbo). It runs by extracting waste heat energy from the exhaust to pump the intake air. So, its an efficiency improver. Efficiency is not the goal, though, by Law. Reduced emissions is. The increased efficiency increases the peak combustion temperatures, which raises NOx levels which must be catalyzed in the converters using added downstream fuel injection. So, its a win loose consequence. Also, a small engine displacement means wider throttle opening, which also increases efficiency by reducing inlet restriction. Try jogging down your road as fast as you can while breathing only with a 1/2" pipe nipple in your mouth instead of a 2" pipe. Its called restrictor plate, same as what asthma sufferers feel.
GM's Displacement on Demand (DOD) also called "Active Fuel Management" works by canceling cylinder thermodynamic addition to the power demand. You can't just shut off cylinders, though, they would go cold and increase carbon monoxide output, so there is active cylinder rotation to keep all chambers warm enough not to misfire.
Remember, ONE misfire during the California/Federal Emissions test fails the vehicle. Real world fuel and power results are secondary to the requirements of the emissions test. Like it or not, makes sense or not, its what non-scientific reasoning has produced for tactics to fight smog pollution increases. I'm still bewildered that our beef and milk cows aren't fed sawdust and equipped with fart collection bags that could be used to power city busses in China.
   / Are Automakers This Stupid? #5
Not a mechanic, but it seems these smaller engines would use less gas and produce less pollution, until you get on it. Isn't that the similar to a larger displacement engine? Not only that, but you can market a larger hp engine that gets decent mileage, that is until you stomp the gas peddle, the you get less mileage, increased emissions and more horse power and a nice kick.
   / Are Automakers This Stupid? #6
My dad worked on autos for 50+ years and did some things that surprised even a few GM engineers. His motto was and still is to some extent "You can buy gas or you can buy parts - take your pick."
   / Are Automakers This Stupid? #7
I remember in the 70s when my Dad was supplying GM. Mostly steel wire for steering wheels. He once told me, how elated the Engineers were when they saved a couple of ounces on a vent duct. Hardly makes sense to me now, considering the massive frames and heavy drive trains of the day. Remember, when you could lift your two ton family car by the bumper?
   / Are Automakers This Stupid? #8
They did other dumb things back then too (;)) , like mandating shock mounted bumpers that could easily shake off a low-speed impact.
Today, because the OEMs get to save $20 in hardware, consumers get to pay $thousands for low speed impacts.
Rgds, D.
   / Are Automakers This Stupid? #9
Not so fast there. Governor Brown just signed the law that gives the California Air Resources Board the authority to regulate bovine emissions (cow farts). They are studying cow feed to see if they can reduce emissions. Guess a vegan diet isn't all its cracked up to be. :laughing:
Cow farts can now be regulated in California | Fox News
Argentina is studying collecting the methane.
These Backpacks For Cows Collect Their Fart Gas And Store It For Energy | Co.Exist | ideas + impact
   / Are Automakers This Stupid? #10
Hey ! That shock absorbing bumper worked when my Mom hit the back wall of the garage driving our 72 Delta 88.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
2019 Kubota RTVX1140 (A50121)
2019 Kubota...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
