Burn Barrel design
   / Burn Barrel design #31
The Sharps Big Fifty replica should be available?
Would you use a Sherman for the burn barrel??
Their old automotive sections (engines, drivelines and tracks) have been used for almost everything else.
   / Burn Barrel design #32
It's called a burn incinerator, made of stainless steel and lasts forever pretty much.
Guarantees not to warp. Comes with a lid and burns so hot it is smokeless after getting to temperature which only takes ten minutes.
Bought mine 2 years ago and can't be happier.
Totally slotted top to bottom for max airflow.
Burn Barrel - Hottest,long-lasting,Warp Resistant Mini Incinerator
   / Burn Barrel design #33
So, Paul, you're using a 'vortex' or 'cyclone' type.
I'm leaning towards this type of design as, for my purposes, the barrel will be used only for tree limb/twig disposal. Perhaps some leaves.
I learnt a new (to me) term in my research; Hardware Cloth. Which I would've simply referred to as a metal 'mesh'. Anyway, it's constantly recommended as a spark-arresting top/lid.
I wouldn't think hardware cloth would last very long with a well designed barrel. Probably burn out in less than one season. Expanded metal mesh wouild be a better choice.
   / Burn Barrel design #35
Cost is north of $400. 55 gal drum at Rural King, $20. I can replace the 55 gal drum a large number of times for $400.
   / Burn Barrel design #37
AND,,, anyone that has owned a propane grill knows that stainless steel "rusts" almost like regular steel when exposed to a flame.
The stainless burner in a gas grill is the first thing to go,, by rusting.
I would hardly expect double the life out of a stainless barrel that is used outside, exposed to the elements.
   / Burn Barrel design #38
AND each time I replace it I get to shoot something.
   / Burn Barrel design #39
There are various types and grades of 'stainless'. Cheaper materials undoubtably used for inexpensive grills.
I understand what you're saying, Mate. :) But the thread title is/was about designs... and joefromga did offer a design. I think that Bird was describing a similar design too, referred to as a 'cage' type.
That being said, I got my 55 gallon drum for free so I'll use what I've got.
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
BULLDOZER ROOT RAKE (A51243)
BULLDOZER ROOT...
UNUSED FUTURE GALVANIZED STEEL SITE FENCE (A51244)
UNUSED FUTURE...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
2018 BOBCAT T770 SKID STEER (A51242)
2018 BOBCAT T770...
